Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
05 Accord Acceleration issues
Old 08-17-2013, 06:20 AM
zomzom's Avatar
Default 05 Accord Acceleration issues
Hi,
Needed some advice on acceleration problems I have been having on my car.
- 05 Accord SE Coupe with ~65K miles (Automatic transmission, 4 cylinder)
- New throttle body (OEM part) was installed two years ago since old one was an aftermarket adjustable TPS and made the car buckle/jerk a lot. Don't notice any problems anymore other than during startup braking as listed below.
- Regular oil changes done, brake fluid replaced recently, tires are in very good condition, new brakes installed a month ago
- Check engine light is not on
Recently, I have noticed that the car will not accelerate even when I keep pushing the gas pedal. Typically happens at around 50 to 60 mph marker (the mph needle will just stall at one location and not move). I have to tap the brake lightly a couple of times or let the car coast down without giving it any gas (it kind of releases whatever is holding the car from accelerating and releases the mph needle). I then accelerate the car again and it will go higher than 60 mph. Keeps happening often (not every time though). My gas mileage is lower which confirms that something is happening.
Also, the car jerks the first couple of times when i use the brake but then works fine.
Does any of this sound like the transmission problems that Accords have had or is this completely different issue? Please advice what I can do to find out the cause and fix the problem.
Thanks
Old 08-17-2013, 06:34 AM
BLKFLSH's Avatar
Default Re: 05 Accord Acceleration issues
If you push the accelerator down, do you feel the transmission downshift? Does the engine rpm needle go up?
Old 08-17-2013, 06:59 AM
zomzom's Avatar
Yes, the engine rpm goes up when I accelerate but I don't notice any downshift. Regular driving, the rpm needle is around 2.25 rpm at 60 mph. When the car does not accelerate and I am still giving it more gas, the rpm number starts climbing towards 3 rpm but speed is still stuck at 60 mph.
Old 08-17-2013, 10:32 AM
BLKFLSH's Avatar
Bad sign. Your transmission is probably slipping. Have you checked the fluid level (check it with engine off)? If the fluid level is low, you might have a chance. You would have to get it checked out by a professional, but it doesn't look good.
Old 08-18-2013, 02:32 AM
DELuth's Avatar
+1
Old 08-18-2013, 08:37 AM
My Name is Nobody
MSchu's Avatar
did you happen to change out the transmission fluid without changing out the filter?
Old 08-22-2013, 01:56 PM
zomzom's Avatar
Sorry for the late reply as I was traveling. I haven't checked the transmission fluid levels yet but will do so this weekend. Thank you for your responses.
accord_cd5
05-11-2016 08:10 AM
carpdiem
08-18-2014 04:10 PM
user54321
09-12-2013 09:48 AM
jsardo
06-28-2005 05:05 PM
alb_accord
12-16-2003 08:44 AM
Quick Reply: 05 Accord Acceleration issues
