Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 Accord sedan A/C problems
Old 05-08-2017, 11:04 PM
gclindsay61's Avatar
Default 04 Accord sedan A/C problems
About a year ago A/C performance deteriorated noticeably and whistling noise in evaporator . Using a Snap On recovery and servicing unit I found both high and low pressures low. (120/20). I found that the receiver drier desiccant had ruptured. I remove the R/D and back blew the condenser with nitrogen. Seemed to be clear. Installed new R/D, Charged with 19 ounces, Pressures the same. I have replaced the Evaporator, condenser, expansion valve, and recently the compressor and blew out all lines with nitrogen. Pressures still 120/20. Stymied! Any ideas? Also I've used 3 different Snap on machines. All with the same results
Old 05-12-2017, 08:25 PM
eksine's Avatar
Default Re: 04 Accord sedan A/C problems
so you're saying it has low pressure? did you rule out a bad compressor? or maybe compressor is plugged up? maybe try blowing out the compressor if you can and change fluid
RFEwing
08-15-2016 10:20 AM
hometheaterman
06-29-2015 04:36 PM
davidterry1958
09-10-2012 06:42 PM
ramsal
07-22-2011 05:19 AM
Quick Reply: 04 Accord sedan A/C problems
