04' Accord EX 2.4... Miserable gas mileage
i recently purchased the car @ 34kmi and im getting roughly 14-16 mi/gallon..
the dealership said they changed part of the emissions control unit, but after 5 days there is no improvement, i can basically watch the needle go down...
any suggestions? PLZ HELP
Re: 04' Accord EX 2.4... Miserable gas mileage (hbombz203)
How are you calculating it? There are ways to do it that seem correct, but are not. You have to:
Fill up the car.
Reset trip meter.
Drive til empty.
Refill.
Divide miles driven by actual gallons put back in.
Please don't take this the wrong way, but a lot of people do it wrong and divide by the size of the tank. Just eliminating the easy stuff.
Fill up the car.
Reset trip meter.
Drive til empty.
Refill.
Re: 04' Accord EX 2.4... Miserable gas mileage (wellinghurst)
its been on several full tanks, i reset the trip counter and drive till just after the gaslight turns on.. its been roughly 230 miles every time.. it should be getting almost 30 from what ive been told.. please if anyone has any suggestions it would be greatly appreciated
Alot depends on highway vs stop and go and idle time. Someone who does everyday stop and goes, leaves thier car on all the time will be alot worse then somweone who just cruises on parkways. Are you sure that little miles per tank? Did you figure out how many gallons it took.
Re: 04' Accord EX 2.4... Miserable gas mileage (Accord1234)
im positive.. its getting under 250 miles on a FULL tank, and its taking almost the full 17 gallons every time i fill
can someone please offer me a suggestion instead of telling me how to calculate gas mileage? any sound technical advice would be greatly appreciated
you should be getting over 350 on a full tank if not 400...is there a check engine light or anything? how about your oil? your ecu could be [freak]ed up too, or they might need calibrate some **** for the gas..try posting up on gen7accord.net, i'm from there too and there are members that know a lot but i have never encountered a issue like yours, maybe one of the other guys will know...but it could be your ecu, if your throwing codes get your codes checked...do you have any mods done to the engine or anything?
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbombz203 »</TD></TR><TR><TD CLASS="quote">i recently purchased the car @ 34kmi and im getting roughly 14-16 mi/gallon....</TD></TR></TABLE>
I'm not sure how long you've owned that car, but my best advice would be to get the dealer to fix it or take the car back before your time for action runs out.
That's seriously just waaaay off base for a K24 in an Accord.
It Wasn't Me!
1 Post
Re: 04' Accord EX 2.4... Miserable gas mileage (George Knighton)
What kind of tire/wheel package does the car have on it? What pressure are the tires set at? What type of driving do you do?
Re: (Elusive K24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elusive K24 »</TD></TR><TR><TD CLASS="quote">you should be getting over 350 on a full tank if not 400...is there a check engine light or anything? how about your oil? your ecu could be [freak]ed up too, or they might need calibrate some **** for the gas..try posting up on gen7accord.net, i'm from there too and there are members that know a lot but i have never encountered a issue like yours, maybe one of the other guys will know...but it could be your ecu, if your throwing codes get your codes checked...do you have any mods done to the engine or anything?</TD></TR></TABLE>
they said that they replaced the evap canister and part of the intake.. i was told by a few people that the car has a computer that has to gage new amounts of air, etc. to adjust the cars performance, so is it possible that it could take some time for the car to adjust?
It Wasn't Me!
1 Post
Re: 04' Accord EX 2.4... Miserable gas mileage (someone else)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by someone else »</TD></TR><TR><TD CLASS="quote">What kind of tire/wheel package does the car have on it? What pressure are the tires set at? What type of driving do you do?</TD></TR></TABLE>
its the 5 spoke stock alloy wheels on michelin all weather tires... they are all inflated at 32 psi, i do a pretty much 50/50 mix of city and highway driving
sorry to hi-jack the thread but....
how many gallons of gas should a 03 accord 6-6 take? i fill up from empty and it usually takes about 12.5 gallons where as ive heard it should take 17?
