Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 Accord Electrical Problem???
Old 02-23-2010, 06:48 AM
New User
gkhuffman's Avatar
Default 04 Accord Electrical Problem???
Hi, I have an 04 Accord Coupe with the v6 motor.
Recently i have noticed an issue while driving at night. the lights seem to dim and brighten. When i accelerate or tap the gas at all the lights dim. About a second after letting off the gas pedal the lights will brighten up again. Has anyone had to deal with this before or know what may be causing it?
thanks for your help.
Gary
Old 02-23-2010, 02:19 PM
TheAsian's Avatar
Default Re: 04 Accord Electrical Problem???
Which lights are you referring to.
Sounds like a bad ground to me. Thats where I would start
Old 02-23-2010, 08:25 PM
90sedan's Avatar
It's a pretty common problem with the 03-04 accords. The ELD is faulty, and the underhood fuse box will need to be replaced as the ELD isn't available separately.
As long as you aren't experiencing any other issues, like difficulty starting the car, replacing the ELD is where you should start.
olskool
12-23-2009 07:40 PM
dasjestyr@gmail.com
02-23-2009 11:29 AM
syeldell
03-23-2007 09:06 AM
sbestman22
03-09-2004 11:57 AM
Quick Reply: 04 Accord Electrical Problem???
