03 Honda Accord Electrical Issues
I have a 2003 Honda Accord EX w/Navi
My clock display started a flickering in a out a while back and would get dim or just not show at all, for a while if I just tapped the dash it would come back in for a while, but eventually go back out.
Also more recently my navigation works, but all of the buttons for the HVAC and radio do not work anymore.
Is anyone familiar with this issue and have a solution via youtube, or a link within this forum with the fix for these issues?
I was searching the forum for a similar issue but could not find the issue here. Seems like its a known problem but can not find a fix for it. Any help would be appreciated.
Re: 03 Honda Accord Electrical Issues
For the clock issue, I had a similar issue with the temperature gauge on my 99 Accord. It would sometimes work when tap the dashboard. It turned out that the solder joint came loose. I had to resolder it. You could check for a similar issue. Look on the circuit board and see if you see any loose solder joints.
The Navigation is a big known problem point on this car. My navigation does not work. I have not figured out a work around for an economical way to revive it.
Jaldy
02-26-2016 04:41 PM
dedehonda
Audio / Security / Video
03-02-2015 02:29 PM
leeanne
11-04-2012 07:12 PM
