03 Accord - No Electric Power
OK, so I think I really messed something up. I was trying to get to a/c compressor so I started to remove alternator. I unplugged the harness on the front, then started to unscrew the bolt holding a connector wire to the alternator...so BIG SPARK when the wrench touched both the alternator bolt and the plenum...(doh! #1) methinks I better disconnect the battery, so I did. Then something came up and I needed to use the car right away so I reconnected the battery, went to start the car but no power....forgot to reconnect the harness (doh! #2). Reconnected the harnes, but no power...no dash lights, nothing. Checked battery fuse and a few others, found nothing blown. Tested battery with meter, seems ok. Yes, I'm a bit of a hack that like to try to fix things but sometimes blows everything up instead. Any help/suggestions are much appreaciated. Thanks!
Re: 03 Accord - No Electric Power
Yep, checked it again....it was the main fuse. I missed it the first time...just a tiny hairline break. Needed to put on my 3X reading glasses to see it. Thanks for the help!
wood181
04-15-2008 06:59 PM
