03 Accord.... Making Noises
While my 2003 Accord 6-6 sits at idle.. the vehicle tends to make a chirping noise coming from the engine area... this only happens when the clutch is not engaged.. when i push in the clutch, the noise goes away... any ideas?
Re: 03 Accord.... Making Noises (JDM_Acccord)
I'm not much help, but I'll give you my .02. Chirping is something just barely, and I mean barely touching and rubbing something else. Try standing beside it while its running and putting pressure on different things (fenders/try jacking a few spots with a tiny amount of pressure/etc). That may help narrow it down. It could be that it's not because you press the clutch, but maybe the way your posture changes simply makes it go away. I tracked down a chirp for years in my old Blazer and never found what it was. Not sure if this helps or not.
delfinli
08-06-2010 02:31 PM
