03 Accord gas door will not release - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 03-19-2008, 04:14 PM   #1
jason72687's Avatar
Default 03 Accord gas door will not release
Does anyone know if there is an alternate way to open the gas door than pressing the button inside the car? The button sticks when you press it and doesn't open the gas door. It will still open the trunk when you pull it up. I looked all over for some kind of emergency release but am having no luck. Can I pry it open if I need to?
jason72687 is offline   Reply With Quote
Old 03-21-2008, 10:03 PM   #2
hbombz203's Avatar
Default Re: 03 Accord gas door will not release (jason72687)
im having the exact same problem in mine.. does anybody have any idea?
hbombz203 is offline   Reply With Quote
Old 03-24-2008, 09:14 PM   #3
hbombz203's Avatar
Default Re: 03 Accord gas door will not release (hbombz203)
bump
Old 03-25-2008, 09:45 PM   #4
hbombz203's Avatar
i figured it out.. take your kick panel off where the latch is and there should be another panel with a screw on top right underneath.. unscrew it and pull it off to expose the metal housing, and you should see a set screw type thing which creates the tension to pop the gas door.. just sit it back where it should be and tighten it, and just make sure both your trunk and gas door open after you screw it in, because it might take some adjustment to get them both to open
Old 04-24-2008, 09:12 PM   #5
git0's Avatar
If you have got it opened by now - I learned from the dealer (when this happened to me) when you fill up with gas and put the gas cap back on - be sure the plastic strap that holds the cap on is away from the latch as it catches and your gas door will not open from the inside. Hope this helps
git0 is offline   Reply With Quote
power lock stop working Blah. Acura Integra 1 01-01-2011 05:33 PM
pressure in gas tank?? released when opened luisrblue Acura Integra 5 03-24-2009 08:56 PM
Viper 5000 help wiring Autoloc door solenoids. BodyKits NW Audio / Security / Video 9 11-05-2006 09:00 AM
Power Door Lock Problem 98 Accord matthew21_79 Honda Accord (1990 - 2002) 7 11-18-2005 06:54 AM
Broken fuel door release handle RichUT Honda Accord (1990 - 2002) 2 09-21-2005 07:31 PM
Tags
03, 2003, 2004, accord, civic, door, emergency, find, gas, honda, latch, manual, problems, release, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
