03 accord caliper/ebrake help
Right rear caliper was sticking so I replaced it and the pads. I bled the brakes and they seem to work well (perhaps a bit spongy) but the parking brake does not work. This is not a stretched cable issue as the lever on the caliper is rotating all the way when the cable is pulled. Help. Thanks
Re: 03 accord caliper/ebrake help
i have same exact problem. where like the caliper freezes right?? and it was on my right rear caliper as well! wow. i think it's from the caliper boot not greased up well or the boot pins are not greased up and are sticking. i dont' know. but i'm gonna replace the pins today and grease them up, or wutever parts squeeze in and out. it might be bc u didn't line up the groove on the caliper with the tab on the back of the brake pad for the inner brake pads. idk wut it could be but i am experimenting around. my rear right rotor is completely shaved down due to the caliper not releasing and they are f*'d up now and i have to replace them, which i am doing today! excited for the job
Kevin Nealis
04-19-2015 07:53 PM
cmyates007
02-22-2010 02:28 PM
