Smart Entry with Walkaway Auto Lock
Hello all -
Just got a new 2019 Accord Sport 1.5 and it doesn't have the Smart Entry w/ Walkaway Auto Lock feature (that I miss from my prior Civic). Does anyone know how much and if it's possible to get this feature installed? Any aftermarket solution? Thank you. |
Re: Smart Entry with Walkaway Auto Lock
Originally Posted by Xcalimus
(Post 51844620)
Hello all -
(Post 51844620)
Hello all -
Just got a new 2019 Accord Sport 1.5 and it doesn't have the Smart Entry w/ Walkaway Auto Lock feature (that I miss from my prior Civic). Does anyone know how much and if it's possible to get this feature installed? Any aftermarket solution? Thank you. 1Locking the vehicle (Walk away auto lock®) The auto lock function is set to OFF as the factory default setting. The auto lock function can be set to ON using the audio/information screen. If you set the auto lock function to ON using the audio/information screen, only the remote that was used to unlock the driver’s door prior to the setting change can activate auto lock. 2 Customized Features P. 381 After the auto lock function has been activated, when you stay within the locking/unlocking operation range, the indicator on the remote will continue to flash until the doors are locked. When you stay beside the vehicle within the operation range, the doors will automatically lock approximately 30 seconds after the auto lock function activating beeper sounds. When you open a door after the auto lock function activating beeper sounds, the auto lock function will be delayed until all doors are closed. When all doors have been closed and the remote is inside the vehicle, or if the remote is not detected within about 5 feet (1.5 m) of the vehicle, auto lock function will not be activated. If you press the unlock button on the remote within the operation range soon after the auto lock function activating beeper sounds, the auto lock function will be canceled. |
