A/C Intermittent cool air
2013 Honda Accord LX
When you first turn on the air conditioner it blows cool air for 5 minutes or less then blows hot air until I turn it off for 10 minutes then when I turn the A/C back on the pattern repeats itself. One year ago on a trip from Flagstaff AZ to California, the A/C quit working altogether in Needles California, I took it to a repair shop they replaced the clutch and clutch coil, $1,200 the A/C worked just fine until two weeks ago, then it started the intermittent cooling described above. I again took it to an A/C shop and they charged the system and it worked very well for one week, then the intermittent cooling started again. Can anyone help? |
Re: A/C Intermittent cool air
Sounds like there may be a leak. You can attempt to diagnose it and check for leaks by buying an AC leak tester with dye and a UV light, you can get a kit at your local parts store or Amazon for fairly cheap.
