Honda Accord (2013 - Current) 2013 - Current Honda Accord and Inspire
2016 honda accord making knocking noise
Old 04-07-2018, 11:55 PM
Default 2016 honda accord making knocking noise
i brought a brand new accord in 2016, for the past few months, noticing a knocking sound coming from the front over humps, uneven road and at times on some turns as well..seems like the driver side. car is only done 50K .. had it checked out at a specialist, they replaced the left front strut(shock mount) as they showed it to me, the cylinder was loose, the right side was firm. in addition, they also replaced the entire rubber cap assembly on the driver side by stating the screw was touching the metal as the rubber had worn off.. i found this hard to believe as this is a new car. after replacing both parts, the noise is still there and now they are saying it could be the suspension or should try replace both sides rubber bushing (cheaper option).. how can a bushing go bad in a new car?
any other suggestions on what could be wrong?
the dealership is charging 150 bucks to just look at the car even though it is under warranty....
shazar is offline
Old 04-10-2018, 08:09 AM
W95 gives me a hard-on
foumer's Avatar
Default Re: 2016 honda accord making knocking noise
Could be the sway bar links too.
foumer is offline
xtrac1
General Discussion and Debate
60
06-27-2016 11:00 AM
adiDAs
34
01-23-2016 05:34 AM
omg_miiiike
08-08-2005 07:10 PM
Quick Reply: 2016 honda accord making knocking noise
  • Ask a Question
Question Title:
Description:
