Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2016 Accord Tachnometer Not Working
Old 10-22-2017, 04:51 PM
otterslide's Avatar
Default 2016 Accord Tachnometer Not Working
Does anybody know how the 2016 accord derives the tach reading?
Which sensor could it be using? The engine works, but the tach gauge does not move. I don't have a scanner to check, but I assume the ECU knows the engine RPM if it's able to run??
I would be guessing the Torque Converter Turbine Speed Sensor might be the one that is used for the gauge? It's sharing a common wire with the Engine Temp Sensor 1, and both Tach+Temp are not working on the cluster.
Also seems by not having temp sensor working, then the coolant thermostat never opens? Is the thermostat/flow of coolant ECU controlled on this car?
Old 10-23-2017, 11:11 AM
HonBeer's Avatar
Default Re: 2016 Accord Tachnometer Not Working
You have a 3 year/36,000 mile basic, 5 yr/60,000 warranty. Take it to the dealer.
Old 10-23-2017, 11:15 AM
otterslide's Avatar
Trying to fix an Accord that had a minor accident.. I'm pretty sure warranty no longer applies now, because any problem could be due to the accident.
I'll figure it out, going to check wiring diagrams soon.
younggun90
09-03-2021 12:01 PM
victor_509
12-08-2015 09:27 PM
kilosage
10-10-2015 06:31 PM
oo_phuong
03-13-2008 07:42 AM
91t4
06-27-2006 12:30 AM
Quick Reply: 2016 Accord Tachnometer Not Working
