2013 Crosstour electrical problem
Sorry if this is the wrong forum for this but I couldn't find a dedicated Crosstour forum.
2013 Crosstour V6. Keyless entry. Occasionally car has battery drain. Starts easily with jump and will be fine for perhaps a day or two. Battery tests fine. Mechanic suggested alternator but I really doubt it as it runs fine after jump. Is there a relay that could be kicking on and draining the battery? Thanks! |
Re: 2013 Crosstour electrical problem
Originally Posted by Marc Chesanow
(Post 51604190)
2013 Crosstour V6. Keyless entry. Occasionally car has battery drain. Starts easily with jump and will be fine for perhaps a day or two. Battery tests fine. Mechanic suggested alternator but I really doubt it as it runs fine after jump. Is there a relay that could be kicking on and draining the battery? Thanks! A new mechanic and a parasitic draw test is needed.....in that order. |
i took a leap of faith and replaced the A/C relay, (It was like $6.50) So far-so good.
