Honda Accord (2013 - Current) 2013 - Current Honda Accord and Inspire
2013 accord sport
Old 04-14-2019, 10:04 AM
Default 2013 accord sport
I changed the cvt fluid, got about 4 quarts, added the new and only 3 quarts and coming out the level hole, what do I need to do now?
mjselling is offline
Old 04-14-2019, 12:20 PM
Global Moderator
tech8's Avatar
Default Re: 2013 accord sport
CVT Capacity: 3.5L (3.7 U.S. quart) at change.
Transmission Fluid Check:
Note: Do not remove the Check bolt before or during refilling of the CVT.
1. Apply the parking brake.
2. Start the engine in P.
3. Move the shift lever through all positions while pressing the brake pedal firmly, and wait at least 3 seconds in each position.
4. Move the shift lever back to P and shut off the car.
5. Remove the Check bolt and sealing washer.
6. The transmission fluid is at proper level if the transmission fluid is dripping from the check hole gradually (a slow and gradual drip).
If the fluid is low, loosely install the check bolt, remove the filler cap and add fluid. Then repeat step #2.
7. With the fluid at proper level, re-install check bolt with new sealing washer.
tech8 is offline
Old 05-14-2019, 02:24 PM
make sure you don't jack up the car on 1 side. if you jack up the car all 4 wheels have to be on the same level.
jesser916 is offline
  • Ask a Question
Question Title:
Description:
