When does VTEC engage in.....
a 2002 Automatic V6 Accord?
Re: When does VTEC engage in..... (ICanSayMyAbcZ)
ttt
Around 3500rpm, but it varies.
Re: When does VTEC engage in..... (F22turbo)
mine does not vary it is always at 3500 rpm
Re: When does VTEC engage in..... (01accordv6)
Can you feel the extra boost right away, because when my dad drives, and i tell him to hit higher rpms, i can't really feel it.
For Misa...
*thud* |
this is heavily debated. some say 3500, some 4K, some say 5250... no one knows for sure... not that I have come across thus far anyway.
Re: When does VTEC engage in..... (greensleeper)
no, it is for sure on the 98+ V6 it IS 3500...no debate...
you can't feel it, but its happening... get an intake and you WILL hear it... it is ALWAYS 3500, it doesn't vary like the 4 cylinder accords |
Re: When does VTEC engage in..... (F23 Power)
no, it is for sure on the 98+ V6 it IS 3500...no debate... you can't feel it, but its happening... get an intake and you WILL hear it... it is ALWAYS 3500, it doesn't vary like the 4 cylinder accords |
I did not know that. Walter. The Big Lebowski. |
Re: When does VTEC engage in..... (HondaSport)
actually VTEC is always engaged...........
you do not hit high cam until the car says so, which varies with RPM, MPH, etc. |
Oh ok thanks for your help. http://images.zeroforum.com/smile/emsmile.gif no, it is for sure on the 98+ V6 it IS 3500...no debate... you can't feel it, but its happening... get an intake and you WILL hear it... it is ALWAYS 3500, it doesn't vary like the 4 cylinder accords |
Re: When does VTEC engage in..... (urbanlegend21)
in the 98+ v6 accords it does not matter what mph it only matters what rpm and i hope you meant to say that it does not hit the high lobe on the cam because the way you worded it it sounds like another cam starts working. Just wondering
On the 4 cyl. accords I was under the impression that the vtec didn't switch to the high setting until 5000 rpm, though i've tested mine in the high 3000 rpm range. When does vtec switch over on the F22's and F23's?
Re: When does VTEC engage in..... (3700 Vtec)
Not this shit again!
On the 4 cyl. accords I was under the impression that the vtec didn't switch to the high setting until 5000 rpm, though i've tested mine in the high 3000 rpm range. When does vtec switch over on the F22's and F23's? |
4750
Re: When does VTEC engage in..... (Accord94DX)
8200.
Re: When does VTEC engage in..... (Wont be beat)
8200. on yours its 8350 dumbass!! |
Sorry, my goof. I launch at 8200.
Sorry, my goof. I launch at 8200. nice G |
