What is your tire pressure???
Old 01-24-2013, 11:26 PM
  #26
holmesnmanny's Avatar
Default Re: What is your tire pressure???
You can go between 32 and 40..don't go higher than 40 and less than 32..oem is 32. I use around 34-36 cause it seems to get better mpg without sacrificing tread wear
Old 01-25-2013, 01:12 PM
  #27
19Accord97's Avatar
I run 35 in both of my cars.
Keep in mind the max tire pressure is the MAX. When you drive your tires heat the air inside and increase tire pressure, so be warned.
Tires that run 80psi are heavy duty and will have an LT before the tire size with a load range of c, d, or e which refers to the # of plies.
benji7288
11-21-2007 01:21 PM
pnoi_01dc2r
05-28-2007 07:24 AM
sporty240
23
08-25-2005 06:25 AM
SkRiBLaH
10
02-16-2004 09:25 AM
TeamTooQuick
03-13-2002 09:25 PM
Quick Reply: What is your tire pressure???
