What can I do to make my 98 accord faster?
I have a 98 accord with headers and a double exit exhaust. I want to make it look better and drive way faster. What exterior work should I get done? Also what should I do to the parts itself? I'm aware I can turbo boost it but thats around $1000 and i don't want to spend that if I do not need to. Thanks
Re: What can I do to make my 98 accord faster?
so V6 automatic?
... oh. it occurs to me that you're either trolling or you need to pick a different hobby. you want to go fast for less $1000 drive it off a cliff.
He knows where you live!
$1k for a turbo setup would be on the cheap side, like way cheap. A single dyno-tuning session for one of my cars was $400. That's just for the tune, that's not any of the parts or labor.
Your car is known to have bad transmissions so it won't take much additional power before slipping and failing. There's no 'exterior work' that is going to make it faster except maybe some lighter wheels and better tires. Despite what the Fast and Furious has told you, neons, stickers, and aftermarket headlights do not add value nor do they add performance.
Spend your money and time on doing maintenance. When was the timing belt last done? When did you change the air filters (cabin and engine)? When did you change the oil? When did you change the transmission fluid? When did you change the spark plugs? Are there any worn out suspension components? etc
tucker paw made a great point no exterior stuff im not sure how all the carbon fiber really helps but heard its to think about. maybe cold air, upping you're plugs injection throttle body thingss like that if the tranny is a known issue look into an aftermarket to avoid that issue. im in the same boat though i have a new civic old new to me and just startin.
"Upping you're plugs" ? No idea what this even means
" injection throttle body" ? Again, really not sure what you mean. Bore out the TB? If you're not also going to port match the intake manifold it's mostly a waste of time and little to no horsepower is going to come from it.
"tranny is a known issue look into an aftermarket " - An aftermarket transmission for a '98 Accord V6 ? Doesn't exist
happycamper86
09-25-2013 08:38 AM
