ecu
Old 07-26-2012, 05:33 PM
xXxVicariousxXx's Avatar
Default ecu
I need an ecu for my 93 honda accord i did an engine swap and it is a b22b engine.
Old 07-27-2012, 12:20 AM
GhostAccord's Avatar
Default Re: ecu
Do you mean an F22B DOHC engine? Is it a SOHC F22B1 VTEC or F22B2 Non VTEC? Or is it a custom built engine (built B20)?
Not sure that I have ever seen a B22B before.
Old 03-08-2013, 09:03 AM
Dwood12's Avatar
Default Re: ecu
there isnt a b22b engine is there?
Old 03-14-2013, 11:35 PM
ReaperMan's Avatar
Default Re: ecu
did some research looks like he used a b20 block with f22 head. or the other way around. its a Frankenstein
Old 03-15-2013, 12:08 AM
holmesnmanny's Avatar
Default Re: ecu
where exactly are you seeing the b22b at ?
Old 03-15-2013, 01:10 AM
bairdandrew77's Avatar
Default Re: ecu
Old 03-15-2013, 04:11 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: ecu
the B22B is just a bored/stroked B20, which I doubt is what the op just swapped into their 93 Accord.
op,
I'm guessing you just made a typo, but just to be sure double check the engine code of the motor you just swapped in. The engine code stamp can be found where the transmission and block mate at the front of the motor.
Old 03-15-2013, 09:07 AM
ReaperMan's Avatar
Default Re: ecu
search b22b youll sell its a b20 block with f22 head
Old 03-15-2013, 09:28 AM
NZXTInerTia's Avatar
Default Re: ecu
Pretty sure touring is right. If the OP had enough knowledge to do that sort of Frankenstein he should be able to find an ECU. Probably meant f22Bx which is a fairly common swap.
Old 03-15-2013, 09:35 AM
Default Re: ecu
I don't think they use an F series head.... and when you Google it there is like one or two threads that even call it a B22B....
I find it annoying when a bored or stroked engine gets labeled like that. Oh wait, I should start calling mine an F24A build. Not only does it look cool and original, it's JDM as F#@k!...lol
Neptronix
08-17-2008 02:00 AM
phillycx
16
10-16-2002 08:21 AM
Quick Reply: ecu
