Replacing Factory Fuel Pump...Sizing Questions PLEASE HELP
The fuel pump in my car has gone bad its a 94 honda accord Wagon with an H22 swap. I have an extra stock 98 civic EX pump in working condition and a walbro 255 will either of these work? Using stock injectors will the 255 be overkill? will the civic pump not be enough? please help thanks in advance!
Re: Replacing Factory Fuel Pump...Sizing Questions PLEASE HELP (BLKCivicPorscheStyle*)
civic pump should be fine.
the walbro 255 should also be fine. if it is the high pressure walbro you MIGHT need to install an adjustable FPR to reduce the base fuel pressure, but shouldn't have to.
I'd install the walbro and call it a day. Since it's a returned fuel system the additional flow will not bother anything.
civicjoe
03-05-2008 12:40 PM
