Transmission clickin sound???
Hi there,
I hav a 02 Accord 4cly automatic, I just wonder that when I change my gear, it makes a clicking sound or crack sound, and its pretty loud. I check and there is no transmission leak, everything lookz great, it may hesitates when accelerating...Im a 2nd owner, and the 1st owner had done modification to this car. Any suggestions, I appreciate your helps |
Re: Transmission clickin sound???
sounds like it's falling apart check fluid level if there any.
Originally Posted by vaspeeder
(Post 47393586)
I have the same issue with my 94 EX. Seems to make the clicking noise when shifting into 2nd. High miles but no problems besides that.
(Post 47393586)
Originally Posted by Alex Ely
(Post 47395006)
Don't fix normal.
could be a bad axle or two bad axles. If the transmission has been serviced at the right intervals then it should be ok.... should be.... Does it click when you turn?
Originally Posted by Silver6gen
(Post 47407253)
you should just buy a new tranny :P
