Timing question
I know that you are supposed to alter the timing when using nitrous. My question is do you do this at the adjustable cam gear or the distributer. I may be wrong but i know that both of these can be altered as far as timing goes.
Re: Timing question (honda8882)
I know that you are supposed to alter the timing when using nitrous. My question is do you do this at the adjustable cam gear or the distributer. I may be wrong but i know that both of these can be altered as far as timing goes. an adjustable cam gear will only adjust cam timing on spray you want to retard the ignition timing, this can be either done at the distributor, or via other electronics, i.e. apex- itc, jacobs mastermind etc..... |
| All times are GMT -8. The time now is 10:48 PM. |
