temp gauge tops out, car not overheating, new sender
1994 honda accord
hey i just started using this forum but ive been on a few other ones. my problem is that 99% of the time my temperature gauge in the dash says that my cars overheating. it goes to the very top of the red.. my car is not actually overheating. first i replaced the sender, no luck. then i replaced the thermostat, still nothing. i took out the cluster and made sure everything was plugged in and it was. no loose wires or anything visible. ive bled the cooling system a few times. every once and a while the gauge will read properly but when i park and turn the car off/on itll read overheating. Even if i let the car sit overnight, as soon as i start it it reads over heating. is there any possibility that it could be the gauge? ive heard they get damaged if they ever max out hot... any advice is appreciated. |
Re: temp gauge tops out, car not overheating, new sender
The lower resistance the higher the gauge reads. Since you have a new sender, you may want to look for a short to ground between the sender and the gauge. Measure the resistance from the sender to ground, then from the gauge to ground; it should be the same.
Originally Posted by Roader
(Post 47073750)
I don't know where it's grounding out if that's the problem.
The sender provides the gauge with a variable resistance to ground. The FSM shows:
Unplug the red sender wire from the sender. Measure the resistance between the unplugged sender terminal and engine ground. Then measure the resistance between the unplugged sender wire connector and engine ground. |
http://www.youtube.com/watch?v=u5kjvh76qWk
i also re wired from the temp gauge in the dashboard to the sender. Does that eliminate the wiring as a problem? Thanks |
Do you have a digital volt meter?
Looking at the wiring diagram, the gauge has three inputs:
Thanks I'll get a dmm ASAP. I was also wondering would a gauge cluster from a 94-97 accord without ABS work with my car?(has abs) not worried about not having an abs light.
Hey I bought a dmm today. Gonna use it after work I'll post the results. Also when I test should I have the car warmed up?
Just to check voltage, it doesn't matter if the car is hot or cold. It does matter to check resistance; use the factory specs above to determine if the sender resistance is in range.
i also re wired from the temp gauge in the dashboard to the sender. |
Originally Posted by Alex Ely
(Post 47081419)
Roader- no, I re wired the sender wire after the problem started. To see if it was the wiring.
Jdm- I know. That statement was separate from the video. |
Okay here are my results:
Wire @ sender to wire @ gauge in dash = 0 resistance (meaning wiring is good?) Sender wire at the gauge reads 45 when car is warmed up (or just about warmed up) This part confuses me: when everything was completely plugged in and car was warmed up but not running i got a reading of 38 (like you said) but then when i turned the key to the ON position i wouldnt be able to get a reading anymore....?? (gauge broken?) please watch the attached video to see what i mean: http://www.youtube.com/watch?v=eYGuR9NKzlk |
(Post 47101674)
Thanks I appreciate it
It looks like the resistance to ground is infinite when you turn the key on, if I'm interpreting your meter correctly.
Check for battery voltage and ground at the meter. If they're good, I think JDM nailed it; you have a bad gauge. There's a coil in the gauge that could be opening when gauge is powered. |
(Post 47105072)
alright well i bought a gauge today on ebay just have to wait for it... ill update once i get it.
Got the gauge! at first they sent me the wrong one (#0187) but i was able to exchange it for free and get the right part #0186 and it works now! Everythings back to normal. Thanks to Group.iwerks for the parts.
I know this is an old thread but I have the same problem and I think I caused it. I was doing the speedo fix and for some reason decided to put the soldering iron on both ends of the resistors where they attach to the gauge. Do you think it would be possible to replace the resistors (if so, what resistance) or do you think I might have fried the coil. There was no burn smell when I did this. Fixed the speedo and broke the temp gauge. :(
wakeing up the dead thread but i have something to ask :)
I drive Civic 91 ED7 D16A9 and since i bought it, i had a problem with my temp gauge or something else... The story is that i turn my car and drive, the temp gauge is just fine (just a lil bit down from half) and when i stop and wait in a traffic jam, temp gauge suddenlu rises needle ande it goes to HOT so i have to turn on heating to reduce the temperature but few days ago i let it to go to the top because i was really angry but nothing hapened. It doesnt boil :/ And fan doesnt work... I drove the car just normally. I changed the sensor that turns fan on, fan works when i wire it directly, gauge sensor is new also...thermostat is new, i did bleeding also...also i changed cluster to see if gauge is fail but its the same...and changed the radiator cap. I dont know what to do else...i think my car is not boiling but i dont know how to fix that bad gauge showing? Could it be that the wire of temp sensor is thin somewhere and it doesent make strong signal? I asked a lot of people but nobody could help. EDIT: Also i was thinking that maybe ground of the cluster is not good? |
Back from the dead again.
I had the same issue, and purchased an oem sensor at 45.00! And it worked. After buying two aftermarket sensors. Has this happened to anyone else before? Sounds like it happened to some of the posters here, including OP |
