speedo goes crazy
speedo goes crazy
hi everyone.....new here to honda-tech but not to hondas....anyway i have never come across this before in all of my years of workin on hondas.
When i drive my 95 2.2l accord more than 20 mins. and the engine warms up the speedo goes crazy....i have replaced the vss and it seemed to help some but its still doing it...also d4 starts to flash.....i have come across hondas that do weird things with bad grounds.....i just wanna know if some1 has come across this before....btw i also checked for wire-rubs and there seems to be none....any help would be appreciated it seems like a ground issue but where !?!.....
Re: speedo goes crazy
im having somewut the same problem with my 94 accord coupe. does your speedo cut on and off or is it all over the place? like unaccurate? because all mine will do is just go from the speed right down to zero. or just back and forth, but when its on its always 100% accurate
it works fine when the car is cold but when it gets warm it bounces or stays at a low speed defiantly off....when the car cools down it will work again until warm....i 'm so confused i changed the vss and cleaned all the grounds....
I have a 1994 Accord doing the same thing as well. Replaced the VSS and it seemed to work for a day and then NOPE. Crazy speedometer for a while and then if it's driven long enough the D4 will start to flash. Mine is obviously an automatic and I'm at 220k. If 3 cars are doing this at once, there's got to be a solution. I'm just hoping that the solution isn't a new transmission. Let me know if you guys figure anything else out. For now, I try to keep my driving under 30 minutes.
well yea that's just it we can only drive them safely for 30 mins then its go with the flow and risk a ticket.....im goin to check all the grounds again but its gotta be something in the engine comp. being that its only when the car gets hot....i may check the wires behind the cluster but im still lost on this.....its really weird but predictable.... BTW: any help from anybody who has had this issue and beat it would be greatly appreciated, i drive with 2 kids in my car and i don't wanna be pulled over for speeding with my kids in the car.....thanks a bunch......
Did you use a new or used VSS? If you have a new VSS in and still having problems the Speedo PC board is most likely the cause. It's a fairly common problem on many older Honda models. I repair the speedometers on the 1994-1997 Accords. I have a repaired board for sale on this site, or I can repair yours. I charge $75.00 for the repair. Check out the link http://hondamarketplace.com/showthread.php?t=2965209
I've used a new VSS. Brand new out of the box. & yes, the speedometer still wants to act wacky after 30 minutes and then the D4 starts to flash. Where exactly is this "board"? Are you talking about the car's actual computer?
Ok. I figured out what the speedometer computer board you're talking about. I can see the little circuit that needs to be checked or soldered on the provided link. However, now I don't know what this new post is about a 3-post connector or what not. Are we talking on the VSS? We're jumping to-and-fro with solutions & I'm getting confused. :] Trying to figure out where I can locate a new speedometer cluster & what now right now to change that circuit if the soldering doesn't work. Should I try something else first? & thanks so, so very f'ing much for the feedback. These are great tips I haven't tried yet and I was getting rather frustrated after the VSS didn't do the trick. I'll be lookin' for more info!
You can try to only resolder the joints on the board but don't be surprised if that doesn't work. On this particular model there is a component on the board that fails, not solder joints. I think a new one from Honda is about $150 or $160. It comes with a guage and pc board. If you're interested I can sell you a repaired board for half the cost of a new one with 30 day guarantee.
I actually might be. I'll have to wait for the brains of this operation to get home and take a look at the new findings. We have to fix this car, if we want to sell it. It's a good running car other than this new problem. I'm really thankful that you happened upon this thread. We've been baffled for a week and a half. It's worth trying to solder if it MAY work. But if you have a feeling it won't, then I'm taking that into account. Thanks again. I see you're in North Carolina. We're in Virginia.
Yep from the big'ol city of Greensboro, NC. My wife's parents have a place a smith mountain lake, VA. Good luck on resoldering, hope it works for you. Keep me in mind if it doesn't.
Thanks. Still working on a solution. Hard on the weekends. We're near Roanoke. & another question- is it normal for my D4 to start flashing? Just trying to make sure I'm addressing the right problem and there's not a bigger one on the way. :]
Do you know how to retrieve trouble codes? You've got a dtc stored you just need to find out what it is. There's a 2 pin Blue connector under the right side dash near the glove box. You need to short those 2 pins and turn the ignition switch to the on position. The D4 light will them blink a code. A long steady blink is 10 and fast blinks are 1.
We think our trouble code read 4-0. My boyfriend is use to reading Civic codes (& says the blinking is at a different speed?) and thinks that 4-0 means a 4 code? & what I was talking about with my D4 is... I'll drive the car for more than 30 minutes and the speedometer starts to not work/act wacky, then when you drive for about 40-45 minutes the D4 starts flashing along with the not working &/or crazy speed readings. ??? Weird?
It's almost as if you still have VSS problems. If you're sure you have a code 4 that code relates to the VSS. Does your speedometer ever read 20 mph with just the ignition switch in the on position? Does it ever stick at a certain mph while driving?
Nope. This is exactly what happens...
My car drives FINE.
I drive my car to work. It's only 30 minutes.
More than that, the speedometer starts going erratic. Maybe after it heats up?
The speedometer bounces all over the place before stopping completely.
Every once in a while it'll move a little, sometime correctly (I use my GPS).
After about 15 minutes after the speedometer starts being weird the D4 flashes.
The D4 NEVER stops flashing.
After the car is parked for 30+ minutes, it won't flash again until you drive for 30+, as mentioned before.
We're totally at a loss.
My car drives FINE.
A NAPA VSS. That's about all I can tell you right now. They had the best deal at the time. It was like $70-$80. I could definitely look more into it if that helps? You're being quite helpful. Again, I'm a broken record, thank you! :]
[QUOTE=dankoboost;45837337]im checking the connector for the vss....thats the 3 pins their talking about....its a 3wire sensor....[/QUOTE
What sort of test equipment do you have? If you have a multimeter I can explain how you can check the VSS signal to isolate the the problem it to the speedo head.
