03 steering wheel removal
Old 09-22-2004, 01:33 PM
BETO736's Avatar
Default 03 steering wheel removal
Did a search and couldn't find any info on how to remove the steering wheel, just one for a Prelude. Is it the same?
Can you point me in the right direction? Link?
Thank you.
Old 09-22-2004, 06:05 PM
C_H_A_D's Avatar
Default Re: 03 steering wheel removal (BETO736)
A Hammer
Old 09-23-2004, 08:26 AM
newdad's Avatar
Default Re: 03 steering wheel removal (mood513doom)
well its pretty simple, there should be some kinds of coverson both sides of the steering, take those covers off now you might be able to see one screew on each side they are T30 size.... once you take those off you can take the airbag out, unplug everything remembering how it goes ...you push and pull on the srs yellow connector.. then there should be either a 19 or 17 inch nut in the middle of steering take that loose now wiggle the steering out till loose take nut off and steering off...oh please disconnect your battey off first and make sure you have your radio code .....hope makes sense and yeah its just like the prelude
Old 09-23-2004, 09:46 AM
BETO736's Avatar
Default Re: 03 steering wheel removal (newdad)
BFH (big fricking hammer) and saw, that was my first option, but then I thought of cruise control, voice command and all the electronic goodies connected to the steering wheel, and wanted to do it more civilized.
Is there a trick or tip to avoid the airbag from exploding on my face? That's my biggest concern.
Thank you. I'll follow directions from the prelude.
Ldo
05-26-2009 03:49 PM
niceprelude
01-30-2009 07:50 AM
speedball3
10-21-2008 11:18 AM
hanskies
05-24-2006 03:34 PM
choi830
10-30-2003 05:13 AM
Quick Reply: 03 steering wheel removal
