Trans filter?
Old 06-07-2012, 08:36 PM
Knightrider03m's Avatar
Default Trans filter?
When doing the transmission service on my 5 speed, is there a filter in there that has to be changed? I'm being told two different things.
Old 06-07-2012, 09:41 PM
jdmcertified909's Avatar
Default Re: Trans filter?
that i know of manuals dont have them. i have a automatic tranny that went out and i suspect its a clogged filter i had hardly any pressure also i think the converter overheated the special paint it had on was peeling off almost everywhere. i am planing on taking it out and replacing it if there is a replacement if not just clean it.
Old 06-07-2012, 10:12 PM
Arthas's Avatar
There is NO filter that needs to be changed.
Drain out the fluid and add 2 quarts of Honda manual transmission fluid. Its about $9 at your local dealer and it will make a world of a difference.
Old 06-07-2012, 10:22 PM
Arthas's Avatar
https://honda-tech.com/forums/honda-accord-1990-2002-2/manual-transmission-fluid-change-info-6th-generation-2567087/
Old 06-08-2012, 11:12 AM
Thanks guys for all of your help. But now it doesn't matter about me doing the trans service myself anymore as now I felt my clutch slip on me while I was going to work this morning. My car is going to the transmission shop for a clutch job on Monday and the guy that is replacing my clutch will also change out the oil for an extra $20.
Old 06-08-2012, 11:48 AM
make sure you get the same transmission back. write down the vin on the tranny and match it later. seen tranny shops rip people off and put other tranny's
mykiraa
03-13-2020 04:10 AM
the soL that could
06-18-2010 04:42 PM
wkdclwnz
09-26-2006 03:56 PM
bluefuse
06-29-2006 09:52 AM
Overmind22
03-28-2004 09:47 AM
Quick Reply: Trans filter?
