Radio code ErrE ?
I've seen some posts about radio codes, unfortunately nothing for the error code I get: ErrE. It's a 2002 Accord. I have the code but I have no idea how to enter it. I tried pressing the radio keys but nothing happens. Any suggestions much appreciated.
Re: Radio code ErrE ?
Are you receiving Erre code after you try to enter the radio code or before?
just dealt with this not too long ago, disconnect your battery for a couple minutes. then plug it in, your radio should not say ErrE anymore, but should let you enter a code. enter the correct radio code and you should be set to go.
Thanks for the responses. Yes, there was an error before (Err8 if I remember right) then I tried pressing some keys and I remember it displayed CODE. I'm not sure what happened next - I think I have pressed some keys and it turned into ErrE. I will try to disconnect the battery as suggested and will enter the code. Thanks all!
Thanks b17... Your post just solved my problem.
