CD6 tranny swap
Old 04-05-2012, 04:53 AM
Sir001's Avatar
Default CD6 tranny swap
Hi guys,
Due to the failure of the automatic tranny, I would like to put a manual gearbox on my jdm CD6. I got everything except the ECU. Does anybody know the way to swap the tranny without replacing the ECU?
It is difficult to got a jdm OBD-1 CD6 MT ECU from the market. The only choice I got is P13 ECU from BB prelude but re-wiring is necessary.
Any ideas from guys...
Thanks a lot.
Old 04-05-2012, 09:31 AM
AccidentproWn's Avatar
Default Re: CD6 tranny swap
CD6 is the SIR right? I just did a manual swap on my CE1 wagon and the OBD1 f22's had a seperate transmission control unit seperate from the ECU. I reused my auto ECU and unplugged the TCU. It runs fine with no CEL. It would be worth checking if its the same for the h22.
Old 04-05-2012, 09:45 AM
GhostAccord's Avatar
as far as I know you can run the H22 5spd with an automatic ECU. Same as AccidentproWn posted.
Old 04-05-2012, 05:25 PM
Sir001's Avatar
Thanks bros,
I would like to confirm do I need to cheat the sensors or works on the harness to start the engine.
BBLineBacker81
09-12-2005 03:14 PM
d15bcrex
01-15-2004 09:27 PM
lunarcry
12-19-2002 06:58 PM
RH+G
05-22-2002 08:26 AM
the DR.
01-16-2002 12:02 AM
Quick Reply: CD6 tranny swap
