Need Help with Immobilizer on 98 accord
I was wondering if any one knew the wire color pinouts on the yellow immobilizer ring plug the reason why I asked is because the plug was riped out and only 4 wires were hanging there. so i cut a harness off another accord but i realize that that plug has an extra wire on there wich is a white with red but i could not find it any where on the harness i i'm assuming that the harness i got from the junk yard was from a different year. now the plug those fit but is the wire color order correct? bucause i'm still not getting the green key light on the dashboard when i tun the ignition on.
Re: Need Help with Immobilizer on 98 accord (mjturboshop_net)
did you change the Immobolizer control unit? if you did you will need to have reprogrammed. what have you done to it?
lazynok
Audio / Security / Video
09-20-2004 02:10 PM
