P1399 Code plus missfire 1%2, p1300 & p0715 I'm completly loss, HELP plz!
Old 04-17-2011, 11:41 PM
zerobacan2's Avatar
Icon2 P1399 Code plus missfire 1%2, p1300 & p0715 I'm completly loss, HELP plz!
Originally Posted by phootbag
Misfires and stalling are not easy to diagnose and unless you have a bunch of money to spend throwing parts at the car, a great deal of automotive understanding or at least some cash to pay a qualified technician to diagnose the symptom it could take a while to get the correct guess through the internet.
That quote from this forums explains the last 3 weeks of my life...
Honda Accord 97 SE 2.2 non v tech f22
I have that code p1399 plus
P1300 = ??? "no info on it yet"
p0715 = Turbine / Input shaft speed sensor a cicuit
and
p0301 Missfire cylinder 1 >> I know it is produced by the mal function
p0302 Missfire cylinder 2
everything started 3 weeks ago by my iddle speed dropping, randomly, then a complety mess by cylinders missfiring ramdoly, but it is weird, it doesnt do it when the car is cold... and it does it more when its hot, now the car work in 3 or 2 cylinders with my car stallin in low and high rpms... any ideas??
EDIT****** I have been reading a lot and it seems like the crankshaft position sensor CKP / or Top Dead Center sensor TDC might be my problem. Am I right?******** Edit
I had changed
Spark plugs
spark cables
distributor cap, rotor
map sensor
fuel filter >>> pain in the ***
air filter
lock up control solenoid
I had check every little vacuum hose
valve clearence
compression is good 125 something in all 4 cylinders my mechanic friend told me
I even bought a obd II scanner
I deliver pizzas on this car and it the only one I have to work.
I appreciate all your help!
Yury San Martin
Old 04-18-2011, 01:34 PM
zerobacan2's Avatar
Default Re: P1399 Code plus missfire 1%2, p1300 & p0715 I'm completly loss, HELP plz!
Anybody???
Old 04-18-2011, 05:41 PM
poorman212's Avatar
Have you looked into egr issues.......
Old 04-20-2011, 09:36 PM
zerobacan2's Avatar
egr issues??? ehhh I dont know, any info on that
Tomorrow I will be changing a fuel injector...
any body was any other info?
Old 04-21-2011, 12:06 AM
holmesnmanny's Avatar
Like poorman said, you should check your egr flow since egr's work only after the car is warm. Clean out your egr ports.
Old 04-30-2011, 08:45 AM
yonipoka's Avatar
try to adjust the valves... that's what i did to my accord with 300,000 miles on it and it goes away
Old 04-30-2011, 10:22 PM
zerobacan2's Avatar
FOUND THE PROBLEM!!!
It was a bad fuel inyector...!!!
car now works perfect... thanks eveybody!
civicEXtreme
08-13-2008 03:55 PM
beatthisspeed69
05-20-2007 08:36 PM
technine
04-18-2007 10:51 AM
VTC_CiViC
02-25-2005 11:34 AM
Quick Reply: P1399 Code plus missfire 1%2, p1300 & p0715 I'm completly loss, HELP plz!
