Over Powered Aftermarket Radiator Fans?
Dear Experts,
I have a
1996 Honda Accord
2.2 liter VTEC
Normally, when driving the car, the
coolant temperature is fine.
So the radiator and fan are working fine.
But a few times since I've owned the car,
the coolant temperature has got really high,
just below the red zone. Fortunately,
no escape of pressure/fluid.
This overheating occurs in hot summer weather.
During a lot of very slow stop and go
driving on the freeway.
I'm thinking that 1) there is not enough
coolant moving through the radiator.
2) And/or there is not enough air flow
So, I had a thought.
Could I install a more powerful radiator fan,
that moved more air?
At Dorman,
This fan is for my 2.2 liter Honda
https://www.dormanproducts.com/p-160...bly&origin=YMM
This fan is for a 3.0 liter Honda
https://www.dormanproducts.com/p-244...bly&origin=YMM
Unfortunately, no specs for the fan's airflow
Q:
Assuming the 3.0 liter fan did fit, and the
fan did move more air,
would this fan help in the
overheating situations?
Thanks a lot
I have a
1996 Honda Accord
2.2 liter VTEC
At Dorman,
Q:
Thanks a lot
Re: Over Powered Aftermarket Radiator Fans?
If you think the the larger one will fit (and that your alternator will support the presumed additional current pull), there is an email techsupport email address on the pages you listed. Ask them for the CFM and amps the parts typically pull.
But before spending money on parts about which you're not certain are failing, I would eliminate the other possible cause you have listed. If the system has crud in it that prevents adequate flow, then eventually, that will be an issue regardless of your speed. I'd also ensure the radiator and A/C condensor fins are not overly clogged as well..
the OE fan is capable of maintaining normal coolant temp even if it's 100° F ambient air temp so long as you're not in competition on a race track.
it was already stated that the coolant level may be low. i would start there instead. then confirm the fan cycles on (you can just let it idle with the hood up for about 10 minutes, or jump the fan switch connector with the key in the on position). since it only happens in traffic, you're radiator probably isn't clogged, but you can still have a look.
Premium Member
When was the last time a water pump and timing belt were done? It's possible the water pump could be eroded. This is especially common in older vehicles that have had non-distilled water in the coolant system.
pyrojeff
10-21-2019 09:50 AM
buster97
02-17-2016 07:11 AM
TailZ
Honda Civic (2001 - 2005)
06-14-2010 10:52 AM
