oil leaking outside transmission fluid pan
initially found it when i changed the transmission fluid. the leaking oil is all over the outside tranny pan, bottom part. it is hard for me to tell if it is transmission fluid or engine oil. The color is brownish.
recently had my engine corver gasket changed but the oil outside the transmission pan is still there, and may be more. so i guess it may be the transmission fluid leaking. if so, what is most likely leaking cause? and how to solve it?
Re: oil leaking outside transmission fluid pan (chibiko)
just a FYI
please add your year make and model to your sig. it makes a HUGE difference as to the advice we will give you regardin the transmission. I am guessing that this is an auto?
pityocamptes
14
07-01-2013 12:56 PM
civictyper99
12
05-19-2004 06:19 PM
