There is a clacking noise on my HONDA Accord/ 91'
Old 08-31-2006, 10:10 AM
bobo03's Avatar
Default There is a clacking noise on my HONDA Accord/ 91'
My honda is making a weird clacking noise around the front two tires, I checked the axles and their fine, I also changed the most of the boll joints....I'm thinking maybe its the barrings but i am not for sure, i was just wondering if anyone else has had this problem, or if someone can help me out...
Old 08-31-2006, 11:28 AM
91akkord's Avatar
Default Re: There is a clacking noise on my HONDA Accord/ 91' (bobo03)
mine just started doing that too and its also a '91 but i dont have any idea what it is, i'd like to know as well
Old 08-31-2006, 11:31 AM
technine's Avatar
When does it make this "clacking" noise?
Old 08-31-2006, 12:03 PM
bobo03's Avatar
Default Re: There is a clacking noise on my HONDA Accord/ 91' (technine)
It started when i would make a left turn....but now it does it when i turn either way and when i'm in the Freeway..
Old 08-31-2006, 02:26 PM
KillerElfboy's Avatar
might sound dumb, but are all your lugnuts tight on the wheels? happened to my friends Avalon
Old 08-31-2006, 03:21 PM
bobo03's Avatar
Default Re: There is a clacking noise on my HONDA Accord/ 91' (KillerElfboy)
I'll check it out....
Old 08-31-2006, 03:29 PM
Papichulo1767's Avatar
CV joints
Old 08-31-2006, 05:36 PM
technine's Avatar
Maybe wheel bearing or your CV joint may not be mated in right on the axle. I had that on my 95 and replaced the wheel bearing to find out that my driver side axle was not sitting right because the CV joint was bearly sitting in the cup and extended almost all the way out of the joint (must've happend when I replaced the clutch).
Old 08-31-2006, 07:19 PM
civicboisi's Avatar
Is it worse when you go over bumps? Check your stabilizer link pins
Old 08-31-2006, 09:06 PM
91akkord's Avatar
Default Re: There is a clacking noise on my HONDA Accord/ 91' (civicboisi)
i notice mine the most when i got over bumps, buts it worse when the bump goes down than it is when the bump goes up
Old 09-01-2006, 10:42 AM
Default Re: There is a clacking noise on my HONDA Accord/ 91' (91akkord)
you mean its worse on potholes than speedbumps?
hookups214
07-21-2008 11:41 PM
campbell10
03-27-2007 03:12 PM
willyd88
11-28-2005 09:28 PM
GrandMarkie
05-15-2002 01:52 PM
Quick Reply: There is a clacking noise on my HONDA Accord/ 91'
