Nut size??
Anyone know what size the rear hub nut is? My Helm's manual says it's a 22mm x 1.5mm but there is no way a 22mm is gonna fit that nut.
Here's a pic of the nut with me holding a 22mm socket up to it. http://img518.imageshack.us/img518/2605/22mm.jpg http://img518.imageshack.us/img518/22mm.jpg/1/w640.png Here's a pic with a 32mm socket.... http://img518.imageshack.us/img518/1408/32mm.jpg http://img518.imageshack.us/img518/32mm.jpg/1/w640.png |
Re: Nut size??
32mm
Re: Nut size??
Originally Posted by sublime423
(Post 37600597)
32mm
Re: Nut size??
it should be 32mm for the rear
Re: Nut size??
Re: Nut size??
36 is the front. It should be a 32mm, I just went into my garage and put an 1.25" socket on it and it fit fine.
What vehicle did this knuckle/spindle come from? |
Re: Nut size??
Originally Posted by GhostAccord
(Post 37601316)
Re: Nut size??
:thumbup: all is good, It's snowing here, and I'm just sitting here next to the fire with my laptop and a Guinness passing time too. I probably have a slight advantage where my garage is attached to my house and it just so happens to contain a fully stripped Accord. I can pretty much measure anything in a matter of minutes :beer:
Re: Nut size??
Originally Posted by JONESER
(Post 37600565)
Re: Nut size??
(Post 37601316)
What vehicle did this knuckle/spindle come from? I suspect that the bearings in the disc set up are bad and I wanna use the bearings from the drum setup. |
Re: Nut size??
(Post 37603133)
My 32mm is too small, 1 1/4" is too small also. It's the rear drum set up from my '91 wagon. I did the rear disc converion about a month ago.
Re: Nut size??
(Post 37603330)
OK so given the information that the drum in question is from a wagon. I would say you have the 24mm diameter spindle, and I would assume that would probably need a 34mm socket.
THANKS! |
Re: Nut size??
Did you find out for sure if it's a 34mm? I know I just tried a 36 on my 93 lx w/drums and it's too big :(
Now I need to get a socket to fit it. Can't wait till I get all this #@#$ back together. |
| All times are GMT -8. The time now is 03:46 PM. |
