95' LX Broken camshaft!
Old 10-01-2010, 10:18 PM
TravisL's Avatar
Default 95' LX Broken camshaft!
I got a call the other day from my brother in law telling me his car died when pulling away from a stop light. Sounded a little like a timing belt gone bad and I gave him the news, got a truck and trailer arranged and went after the car. I took the valve cover off, belt was fine.......friggin camshaft litterally snapped in two. Its clear to the passenger side where it broke and I think it only effected one pair of valves and they seem to be in the 'up' position, hoping they are ok(any input here would be great). I hope to be able to find a good used camshaft to put in it and get it running again?
thanks for any input guys.
Old 10-02-2010, 05:43 AM
GhostAccord's Avatar
Default Re: 95' LX Broken camshaft!
That is very rare....Obviously you were going to remove the head anyway so I would look a bit deeper into this than just replacing the cam shaft and one set of valves. Look at all the valves and pistons and check for impact marks.
A good condition used cam can be had for $100-$150 (maybe cheaper in your area)
Old 10-02-2010, 05:51 AM
lazlong's Avatar
Buy a new cam. Have the head re-worked. Much easier to let the guys with the expertise and machines do this
Old 10-02-2010, 07:05 AM
Daughter not possible
Rude Awakening's Avatar
If it's a F22 car, cant you get a whole motor for $200? That'll be less than re-working and machining anything.
Old 10-02-2010, 07:07 AM
be professional
Targa250R's Avatar
Most broken camshafts I've seen are caused by constantly running the engine low on oil. Oil starvation in the top end cases the cam to seize up in the journals. I'd venture to guess that the internals of that engine are in horrendous condition and that it burns oil profusely. If you make the repairs, chances are that your brother-in-law will continue to neglect his oil level on a regular basis and it will probably happen again.
You may want to consider just paying $250 for a complete used engine from a salvage yard and swapping that in rather than spending the same amount or more messing with the current one. Swap the manifolds and distributor, put on a new timing belt, water pump, balance shaft belt/seal/retainer, thermostat, plugs, fill it up with fluids, and ship it. Cross your fingers and hope you don't get another major oil burner.
Most importantly, make sure to constantly remind your brother-in-law to keep an eye on his oil level in the future.
Old 10-02-2010, 07:12 AM
redbull-1's Avatar
I agree with the others' posts about getting a good used motor instead. Even one of my mechanic friends regularly just replaces the motor on the 5th and 6th gen Accords with a used one instead of fixing any major problem.
Old 10-02-2010, 07:17 AM
be professional
Targa250R's Avatar
F22 and F23 engines are so cheap and plentiful that it's usually the most cost-effective solution. Good machine work is expensive these days.
noahcount
05-24-2011 01:39 PM
webster426
07-12-2009 04:35 PM
mrfett3463
Classic Hondas
05-30-2009 08:19 AM
shbrown
05-09-2005 02:54 PM
EKB18BPR3
05-31-2004 02:34 PM
Quick Reply: 95' LX Broken camshaft!
