Re: At my wits end.
Originally Posted by TheMuffinMan
(Post 45188063)
Interesting, never heard of this - any reason for it?
(Just curious)
Originally Posted by stang7043
(Post 45188140)
Ive read a few post / threads about this. And some people say not to some people say its ok. Since I had to extended the wiring I used it on the plug side but not on the o2 sensor side. From the threads Ive read people say the heat from the soldering iron can damage the o2 sensor or the soldering and wire metals are different and contract and expand at different rates. So that could break the solder joint. But I would like to know why also.
Re: At my wits end.
Originally Posted by DCFIVER
(Post 45189299)
It has nothing to do with the solder material. It has to do with the fact that the O2 sensor uses reference oxygen derived from the path of the wire. Soldering the wire will inhibit the path an can/will give false or erroneous readings. Some O2 sensors use the body of the sensor itself to obtain the oxygen reference(denoted by holes/or slots in the body)
Re: At my wits end.
Originally Posted by kegobeer
(Post 45189730)
I've never heard that before. I always thought the O2 sensor generated voltage based on the amount of mixture going over the tip. More oxygen = less voltage, more gas = more voltage. I thought the computer supplied the base voltage, and a good solder joint shouldn't affect that at all. Or am I way off base here?
*This info excerpted from Bosch training* |
Re: At my wits end.
Ok, I see. But how does soldering wires above the sensor come into play? If one side of the sensor is in the exhaust stream, the other end of the sensor is in "clean" air, the electrodes on each side provide the electrical output, and that voltage is sent to the computer, I'm not seeing how soldering the wires outside of the sensor would interrupt or impact the sensor operation. Is it the heat generated by the soldering iron going to screw up the electrodes, and if that's the case wouldn't a heat sink prevent that damage from happening?
I appreciate the schooling on how the O2 sensor works, DCFiver. |
Re: At my wits end.
(Post 45190192)
I appreciate the schooling on how the O2 sensor works, DCFiver. Lets make this easier, you will not find one "universal" O2 sensor with instructions to solder an O2. They specifically tell you to crimp and splice the wires. It would seem to be wisest to utilize the parts manufacturers instructions would it not??? |
Re: At my wits end.
(Post 45190806)
