Is my auto tranny toast?
91 Lx accord - Got out of work early and put it gear and it was just dragging as if driving w the e-brake on. I check and tranny fluid was empty (unaware to any trans leaks) I drive home 15 mins (having to shift the gears manually)& then put 1qt of OEM in it (all I had) - drive around the block no improvement. Drive back to work in the morning & on my lunch break I go to Honda and put another quart to bring it level again, still no improvement. Gears do not shift automatically. 1st gear isnt as strong as it use to. Is the transmission hosed?
Re: Is my auto tranny toast? (99problemssss)
I think it probably is toast. Trans shop can tell you for sure. Sorry. A junk yard transmission from a place that will give you a 90 day warranty is best. I drove one another 100,000 with zero problems.
tranny is toast +1
