Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Accord (1990 - 2002) (https://honda-tech.com/forums/honda-accord-1990-2002-2/)
-   -   Maintenance Required light!?!?!?!?! (https://honda-tech.com/forums/honda-accord-1990-2002-2/maintenance-required-light-219139/)
MaD3 In JaPaN Jun 29, 2002 02:09 PM
alright earlier i noticed that, that little square box on the bottom of my speedometer, looks a little like it's on, lighted up a little bit, but it use to be orange and now it's red.....what does that mean, i know it's maintenance required but what does the orange and red color mean, also what are the possibilities making this light go on, does it also stay on when the car is off??????please help.
97accordse Jun 29, 2002 02:17 PM
Re: Maintenance Required light!?!?!?!?! (New2HD)
its not a light, its a little tab that turns colors, it goes to red after 7500 miles, its easy to reset, what year is the accord?
MaD3 In JaPaN Jun 29, 2002 03:00 PM
Re: Maintenance Required light!?!?!?!?! (97accordse)
it's a 94, but why did it turn red and why is it on?
97accordse Jun 29, 2002 03:29 PM
its only hooked to the odometer, its not a real indication of anything wrong with the car, just a reminder to do service. If you look in the owners manual it will tell you. to turn it green, stick your key in the small black hole that is on the plastic right near the "light", that will reset it http://images.zeroforum.com/smile/embeer.gif
MaD3 In JaPaN Jun 29, 2002 03:54 PM
oh o.k. thanx, i was soo worried my car was f*cked up.....thanx for ur help man.
97accordse Jun 29, 2002 04:04 PM
no problem
YeuEmMaiMai Jun 29, 2002 04:43 PM
Your car will self destruct in 10 seconds.......I find that that indicator is a neat little reminder for me to check things on the car like brakes, CV boots and now i am 200 miles away from a Timing belt replacement on my car...
YeuEmMaiMai Jul 5, 2002 04:35 AM
Re: Maintenance Required light!?!?!?!?! (Ti1301)
I change my oil every 3K and the little sticker they put in the upper left corner reminds me when it is time again..
lambo93acc Jan 25, 2018 05:52 PM
?so what if my light was red when i bought it .. and now its green????..... an dwhats the whole proceedure to reset a '93 accord maintenance indicator?
MAD_MIKE Jan 27, 2018 11:56 AM
If you have had your oil changed, then the tech would have reset the indicator. It's not a light.
Look on your dash, there should be a little rectangular button in the lower left corner. Use your ignition key to push it to reset after an oil change.
