5th gen clutch cylinder
Old 02-01-2009, 01:46 PM
tamadrummer1120's Avatar
Default 5th gen clutch cylinder
I am doing the auto to 5 speed swap, can anyone with a manual trans or has done this swap, take a few close ups of their 5th gen accord clutch master cylinder placement, trying to make sure I get the right spot for the hole, Thanks guys!!!
Old 02-01-2009, 02:59 PM
P_Adams's Avatar
Default Re: 5th gen clutch cylinder
The provisions for mounting the Clutch Master Cylinder should already be there. Honda manufactures one firewall (for all applications), capable of provisions for both an Automatic or Manual control installation. Once you get the pedals hung, it will be obvious where the cylinder goes. It should be no more difficult than locating the block-off plug/plate.
On USDM Accords it should be just to the left of the Brake Booster / Master Cylinder assembly.
Old 02-01-2009, 05:02 PM
ok, me and my uncle are going to mount it up and i wanted to make sure, I though it mounted to the right of the brake booster, like if you are looking at the firewall?
Old 02-01-2009, 05:14 PM
P_Adams's Avatar
Always as if you're sitting behind the wheel (assuming we're talking about Left Hand steering)
Old 02-01-2009, 05:22 PM
Lol, i wish we were talking RHD. Can you tell me if these are all the parts I need for the pedal and clutch part of the conversion?
http://cgi.ebay.com/ebaymotors/94-97...Q5fAccessories
And can you tell if there is a slave cylinder with the clutch cylinder and the lines? I believe there is, but hard to tell. I am just going to bypass the dampener any how with the SS line straight from the master to slave so the lines make no difference to me.
Old 02-01-2009, 06:03 PM
and also, where is the wiring that would go to the shifter?
Old 02-01-2009, 06:44 PM
P_Adams's Avatar
It appears the ebay items are the hydraulic portion (it's hard to pick out everything) from the master to the slave.
Do you have the pedal / bracket and switches?
How about the shifter / cables etc?
Old 02-01-2009, 06:49 PM
I am ordering those two ebay items and this one:
http://cgi.ebay.com/ebaymotors/accor...Q5fAccessories
What else should I need? And any idea where I could get it or the actual honda part number?
Old 02-02-2009, 09:31 AM
any idea anybody?
Old 02-02-2009, 12:09 PM
P_Adams's Avatar
You already have these?
http://cgi.ebay.com/ebaymotors/94-97-honda-accord-OEM-5spd-clutch-pedal-conversion-set_W0QQcmdZViewItemQQ_trksidZp4634Q2ec0Q2em14QQha shZitem200304356133QQitemZ200304356133QQptZMotorsQ 5fCarQ5fTruckQ5fPartsQ5fAccessories
P
Old 02-02-2009, 02:21 PM
I am getting those, and that clutch master/slave cylinder set.
Old 02-02-2009, 05:46 PM
Isn't there wiring though that comes off the clutch pedal bracket somewhere and goes to the wiring by the actual shift linkage? Or am I wrong?
Old 02-04-2009, 11:30 AM
bump? anyone?
lunarcry
12-29-2002 10:14 PM
CmptchAV6
02-28-2002 09:59 PM
Quick Reply: 5th gen clutch cylinder
