installed new sound system....no antenna?
hi! been going through these forums for 2 weeks now, reading how to fix some problems with my 95 accord lx. but 1 problem i need to fix i cant seem to find.
i got this car with NO radio/speakers. i put a new head unit and also put in some MTX speakers in the doors and the rear window. hooked up the head unit only to find NO radio stations come in.
i did a walk around and noticed theres no antenna or any holes in the body for a antenna. i have the antenna wire plugged in to the head unit.
wheres the antenna? or am i missing a power wire that needs to be hooked up?
PS. the factory wire harness for the factory radio was cut off so i had to go through and sort everything and find out what was what.
Re: installed new sound system....no antenna?
if its a 94-97 coupe/96-97 sedan its in the glass...if its a 94-95 sedan it should be on the body unless someone removed it
its a 95 coupe. maybe the antenna wire for the head unit is bad? guess ill go through that tomorow. thanks for the reply.
