94 ACCORD CEL stays on- code gives me no flashes just stays on solid...
Old 08-22-2006, 05:25 PM
coolrahool's Avatar
Default 94 ACCORD CEL stays on- when checking for error code it gives me no flashes just stays on solid...
94 accord, engine light came on , i did the error code check and the light came on and stays on. Is this considered a code 1 or is it supposed to flash one time and go off. code one for my car is faulty O2 sensor
Modified by coolrahool at 7:10 PM 8/23/2006
Old 08-22-2006, 05:28 PM
hondadude's Avatar
Default Re: 94 ACCORD CEL stays on- code gives me no flashes just stays on solid... (coolrahool)
Not a code one, reset the ECU and if the problem recurs it's probably a fault in the ECU or blown fuse for the ECU
Old 08-22-2006, 05:30 PM
xbn83's Avatar
If you have a solid CEL whether the service connector is jumped or not jumped, that is a faulty ECU code.
Old 08-22-2006, 05:48 PM
coolrahool's Avatar
Default Re: 94 ACCORD CEL stays on- code gives me no flashes just stays on solid... (xbn83)
I for got to mention thati did try to reset the code on more than one occasion and the CEL still just stays on. And for the record i never noticed any real change in the fuel consumption...
Old 08-23-2006, 05:04 AM
Hondaman56's Avatar
Location: Filthadelphia City of Brothers and Love, PA, USA
This is what happened to my 94. I got a CEL steady on to let me know something was wrong. I jumped the connector under the glove box and got one quick blink them a solid CEL. Reset the ECU and try again. You have to keep your eye on the CEL to make sure you catch if it blinks once. Mine was a faulty O2 sensor.
Old 08-23-2006, 06:16 PM
coolrahool's Avatar
Default Re: 94 ACCORD CEL stays on- code gives me no flashes just stays on solid... (Hondaman56)
Hey Hondaman56,
I just went and checked the error code again by jumping the connector making sure this time to watch closely to see what the engine light does.
For sure i can say it does not give me any sort of quick flash, as soon as i have it jumped and turn the key to the on position it simply justs stays illuminated -no flash(es) whatsoever).
I also checked my ECU fuse(it was fine) and also reset it by removing the back-up fuse for 10 seconds. Same results...Once i start up the car my CEL stays illuminated all the way until i turn the car off.It's been this way for months with no real noticable reduction in performance
Old 08-23-2010, 02:39 PM
teg your it's Avatar
OP, did you ever learned how retrieve the code?? my accord is doing the same except mine doesn't start.
Old 08-23-2010, 02:51 PM
He knows where you live!
TheMuffinMan's Avatar
Jesus christ, a 4 year old thread bump for this?
There's a bunch of threads on how to retrieve the CEL. Blue service connector behind/below the glove box, stick a paper clip in it and count flashes.
Old 08-23-2010, 06:17 PM
tamadrummer1120's Avatar
yesssssssssssssssssssssssssssssssssssssss.
its almost worth finding the first thread ever and start bumping threads from there!
its not in the FAQ section or anything like that.
F.
Old 08-24-2010, 07:43 AM
guess what *******. mine isn't blue behind the glove box, and it won't blink. you shouldn't even post, its worthless.
Old 02-29-2020, 10:25 AM
stixoffire's Avatar
Seriously did you read the Thread ? .. Using the Blue Connector to Check Codes Jumped the Blue Connector ..- Code Light STAYS ON .. does not blink but stays on.... that means person placed jumper between the pins on the blue test connector ...
pedroa06
02-09-2010 02:42 PM
esca
10-14-2004 06:34 PM
1.8Tities
09-09-2003 02:11 PM
thefordmccord
04-03-2002 04:02 PM
PiYoImuT
08-22-2001 09:59 AM
Quick Reply: 94 ACCORD CEL stays on- code gives me no flashes just stays on solid...
