Coolant Temperature Sending Unit -2000 Honda Accord
Old 10-25-2009, 06:27 AM
New User
Choc-Thunder's Avatar
Default Coolant Temperature Sending Unit -2000 Honda Accord
My temperature Gauge does not work at all on my 2000 Honda Accord. I was told that it is more than likely the Coolant temperature Sending Unit. Where is this located on a 2000 accord? I know that the ECU temp sensor is below the distributor cap but I do not see an input for another sensor. Is there only one on this model?
Old 10-25-2009, 06:49 AM
HONDAPARTSMANMIKE's Avatar
Default Re: Coolant Temperature Sending Unit -2000 Honda Accord
i believe it only has the one sensor which controls both the gauge and the ecu
Old 10-25-2009, 07:16 AM
New User
Thanks for the reply, I am going to try replacing this and see what happens.
Old 10-25-2009, 02:56 PM
fiveten's Avatar
If you use a scan tool and can see the temp the ecu is reporting then the sensor is ok. the ecu sends the temp command to the gauge.
-Here is the temp gauge test.
fiveten
File Type: doc
younggun90
09-03-2021 12:01 PM
Brett Lushia
01-19-2019 05:37 AM
Jay Wang
09-22-2018 10:57 PM
Kevins89notch
21
03-09-2016 01:25 PM
maluhawk
06-10-2013 01:24 AM
Quick Reply: Coolant Temperature Sending Unit -2000 Honda Accord
