1990 Accord - Engine Temperature Fluctuating
My 1990 Accord (5 sp) engine temerature recently started fluctuating
as folllows : 1) start car and allow to warm up - Engine temp normal, 2) Put in gear and driive along on flat road, or go up hill - Engine temp normal, 3) Go down hill with car in gear, take foot off gas - Engine temp drops fairly quickly ( ~ 1 minute) to coldest point on the gauge 4) Engine temp comes back to normal going up hill
5) Engine temp comes back up to normal on level road, buit takes a little while after coming down a long hill
It's winter here, and cold outside. Heater is blowing warm air, even following a Normal->Cold cycle pattern, although, It could be warmer
when gauge is at coldest display.
Any ideas ??? Thermostat ???
Thanks !!!!!!!!!!!!!
Re: 1990 Accord - Engine Temperature Fluctuating (gimme789)
Have you added, or changed the coolant lately? Is it low? If the answers are no, and no, I would check the thermostat, and the temperature sensor.
dderolph
Honda Accord (2013 - 2015)
03-05-2019 09:25 PM
