how many miles does your accord have on it?
Old 01-02-2018, 06:16 PM
  #576
bob441's Avatar
Default Re: how many miles does your accord have on it?
I have 3 1997 accords #1 EX 312,000 I drive about 900 miles a week in this one Runs ok. Car #2 Ex 155,000 runs like a champ #3 LX 302,000 I personally put 185,00 on it. I think this one runs the best but I got t boned and It leaks air and water around the door so I parked it
Old 01-04-2018, 01:19 PM
  #577
DredEAgle87's Avatar
Mine 90 coupe has about 126k hope it will last me forever for the little I drive. But the auto trans is giving me some headache.
Old 01-05-2018, 11:12 AM
  #578
Smcneal1970's Avatar
Originally Posted by professorman
My 94 5spd LX Accord just rolled 103,000 miles. Since i bought my first car, i like to upgrade my car often as i get a little more cash. I was wondering how much reasonbly longer i can hold on to this car, since there is nothing major wrong with it. My reasoning is that the more maintenace work i do on it, the harder it is to sell it and for example get a upgraded model accord. I have changed the CV joints, which usually go about 100k miles. I now have lifetime Alignment on my car and lifetime balance on my tires. The clutch still feels fine. If i have to change the timing belt, might as well i keep the car. Am I in a detrimental treat already to change the timing belt since it just gone over 100k miles?
How many miles are you guys getting out of your accord and it still be totally problem free?
I am OK with doing maintenance work on it, but just want it to still be reliable.
EDIT: 10/2/2013
Check out the OFFICIAL Honda high mileage club: Honda Mile Makers - Official Honda Web Site
I now have 290k miles using dino oil changed every 3.5k miles, and towing trailers since 150k miles. This tread is inspirational to know how long I can expect to keep my Accord.
High Mileage Club Records: >250k miles
3/21/2004 - 337,326 miles (89 Accord LXi) All original motor, tranny, etc - 89_LXi
3/21/2004 - 242k miles (91 Accord) runs strong - KDKane
3/21/2004 - 306k miles (86 Accord LXi) friend's car, no major problems, fll power, drag races at times - Must be VTEC
3/21/2004 - 275k miles (93 Accord SE) daily driver - AngryTroll
3/22/2004 - 260k miles (90 Accord EX Coupe) John Gordon
3/23/2004 - 323,XXX miles (92 Accord) f22a6 - k-mart
3/23/2004 - 302k b4 swap (91 Accord Wagon), 240 b4 swap (92 4dr Accord), 240k b4 swap (95 Accord) - All still running strong at time of transplant - JDMHatch101
3/24/2004 - 259,000+ (94 Accord) - 94JadeAccord
3/24/2004 - 247k (91 Accord LX) Runs new, burns no oil, idles smooth, no problems - itr 00 0108
3/31/2004 - 230k miles (90 Accord 5spd LX) runs like a beast - Accord_Speed
3/31/2004 - 283k (89 Accord) Still running - freakindross
4/1/2004 - 265k miles (427,000km) - (89 EXi Accord) original clutch lasted until 263k miles -sketcherton
4/1/2004 - 296,700 miles (92 Accord) first clutch died 290k miles - fbiguy007
4/3/2004 - 234k miles (86 Accord) Best winter car ever - showbiz
4/4/2004 - 308k miles (93 Accord EX) - briq4
1-5-2018 -296,678 1992 accord. Just replacing clutch now. Everything else is still origional
Old 01-11-2018, 05:22 AM
  #579
Connor Wile's Avatar
My 02 sedan original motor and trans has 287 thousand and still runs like it’s new. Just gotta keep up on the regular maintenance and your set for life !
Old 01-17-2018, 02:25 AM
  #580
meletis_m1's Avatar
My Accord 2003 European Model (D16b6) has 390.000km.
Old 01-18-2018, 08:30 AM
  #581
flash3825's Avatar
My 2002 Accord EX sedan, original motor and transmission, has 356K miles and counting. Runs and shifts and drives like new. Just change the oil every 3K miles and trans. every 30K miles, tune-up regularly and timing belt/water pump/valve adjust service when due. Only changed the radiator and thermostat and brakes and tires in addition to engine service.
Old 01-18-2018, 02:15 PM
  #582
3ABM581's Avatar
I picked up this grey '91 Accord LX back in September from the original owner and got it running last month. It needed a lot of motor work, but nothing outrageous. It's got 383k on the original motor/trans! I got about 500 miles before the ICM gave out on me today.
https://imgur.com/a/Zuq1N
Old 01-19-2018, 12:37 PM
  #583
chugchuuug's Avatar
1991 Accord EX Wagon - 64,484 original miles, driven every week.
Old 01-26-2018, 05:48 AM
  #584
1trucavalier's Avatar
1995 accord lx sedan manual 221k
Old 01-26-2018, 02:35 PM
  #585
MM Gruppe B
MAD_MIKE's Avatar
Nov '17 the '95 EX original engine reached 340Kmiles.
Before there was a low level cold piston slap on cylinder four, finally became a very loud constant piston smack and excessive blow-by made keeping oil in the crankcase a bit of a challenge.
The F22B1 is dead!
All hail the F22B!
Strangely, the only seal that did not leak was the balance shaft seal.
Old 01-26-2018, 07:08 PM
  #586
2001GSRSC's Avatar
2001 Accord LX F23 SOHC 5 speed manual....145,000 miles zero problems after services. Somewhere along the way I turbocharged it.
Couple thousand miles ago it was rehab'd , suspension , exhaust, engine, brakes. Mostly stock F23 SOHC , 650cc R/C injectors, Hondata, T3/04e ball bearing , Tial Wastegate .5 bar spring/ BOV / and boost control solenoid, Synchrotech H22 5 speed /carbon fiber sychros/ far off .685 5th, LSD, 4.64 final, Aquamist, NOS, etc, etc..
Old 02-20-2018, 06:15 AM
  #587
CRZ1's Avatar
97 accord lx 4 cylinder 199,990 miles, will pass 200k when I drive home today.
Last year, spent $100 more to get a life time alignment from bridgestore, wish I purchased it in 1998. Now prepare to change the timing belt either this year or next year.
Old 02-22-2018, 05:37 PM
  #588
hondaslave1342's Avatar
My 1997 special edition accord is all original..i have every service record from the first oil change..driven 10k in 13 years..currently has 88,000...mint..mint..bought it for $500.. 2008 civic has 179k and the silver 2012 civic has 87k..my 2002 civic has 169k
Old 02-22-2018, 05:39 PM
  #589
nice..want to sell it..
Old 02-24-2018, 06:04 PM
  #590
RedDailyDrive's Avatar
276,000 . 99 accord coupe . J30a1 . Original engine and trans .
Old 03-06-2018, 08:45 AM
  #591
jlwallnc's Avatar
1992 Accord DX ~74k miles
1992 Accord EX ~246k miles
Old 03-12-2018, 07:31 PM
  #592
550k's Avatar
Well before I took it off the road last year, we had rolled 750,000. 2nd engine about 50k on that. 91 honda accord 5 MT on Honda High Miler list
Old 03-13-2018, 07:34 AM
  #593
biPolarbear's Avatar
I have a 1994 accord with 130xxx runs so good but the brakes atm arent working correctly
Old 03-16-2018, 07:53 PM
  #594
XRACER63's Avatar
Default Re: how many miles does your accord have on it ? My 98 Honda Accord Coupe Ex V6 has 1
EDIT: 10/2/2013
Old 03-16-2018, 07:58 PM
  #595
XRACER63's Avatar
98 Honda Accord Ex Coupe V6 emerald Pearl Green has 139,,000
EDIT: 10/2/2013
Old 03-20-2018, 08:02 PM
  #596
Nunfi23's Avatar
324xxx and going up on a 92 accord coupe
Old 03-20-2018, 08:28 PM
  #597
3ABM581's Avatar
Dude...I hope you have a garage for the '97.
And to the guy with the 750K car: what mods are on the car? Where in the world are you, and has rust damaged yours at all?
Old 03-20-2018, 10:54 PM
  #598
Tikal's Avatar
200,000KM 93 SE
Old 03-21-2018, 06:38 PM
  #599
Nope..it sits outside..like i said..i have every oil change from the very first one..ive had 3 1997 and this one is nice..i drive the other honda's just to keep the milage down
Old 03-22-2018, 11:32 AM
  #600
owen.t's Avatar
97 accord v6. 254k km
It runs but it needs some things to make it perfect again.
Quick Reply: how many miles does your accord have on it?
