How to fill my honda accord abs modulator reservoir?
Hi guys, I'm trying to find the proper way to fill the modulator reservoir. I found this video but what I'm having trouble doing is filling it with fluid. The fluid just stays at the top and it doesn't go down to the tank. Do I need to release all the pressure from the bleeder bolt and then fill it or is there another way?
Thank you!
Thank you!
Re: How to fill my honda accord abs modulator reservoir?
Its fairly simple, but considering it took me awhile to figure it out myself when I first got my car I won't flame. lol
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
you must have been trying to put it in the bleeder now it will have to be bled if you opened it
NZXTInerTia, let me clarify, I am able to get to the part where I remove the white reservoir cap off but when I try to pour fluid in there it won't go down.
Oh, you probably filled it then or it doesn't need filling. It is a very very tiny reservoir that holds very little fluid.
MM Gruppe B
If you wish to replace(bleed) the fluid in the ABS then yes.
It is pressurized via the accumulator so add about 3-6' of hose and have it dump into a container, crack the bleeder 1/4 turn and the system will bleed/depressurize the fluid. Turn car and in a few moments the ABS motor will kick on to pressurize the system and drain the tank down to near the bottom.
Turn engine off > Refill reservoir > Crack bleeder > Turn engine on.
It will easily take 3 cycles to bleed, I usually do 5 cycles to be sure.
Thank you guys! Well just as NZXTInerTia had suspected, the tank was already full! Why I didn't realize that beats the hell out of me!!!
Sergey.R
06-23-2015 10:32 AM
