HELP car won't start
I have a 2000 honda accord i changed the spark plugs, spark plug wires, distributor but it still won't start. I got spark but don't know what could be causing it to not start does anyone have any ideas? Any help would be much appreciated
Re: HELP car won't start
Check engine light? Is your fuel pump priming?
Originally Posted by Blaze45
(Post 48756667)
Could it be my crank sensor?
Unscrew the bleeder bolt on the fuel line/rail. Prepare a rag and have somebody turn the key to the second position. Should squirt fuel when the key is turned.
Check cam timing to make sure it is correct. Check engine grounds. |
(Post 48757156)
dont just assume no codes...check to be sure
Posted from Honda-tech.com App for Android |
Originally Posted by holmesnmanny
(Post 48759634)
