Super smooth tight fireing engine
i was at the track the other day and there was one car in particular had a super tight sounding engine. it was a v8 5 something liter. but i noticed Bisimotos all motor dragster has that same tightness. how do i achieve this?
in other words. i couldn't hear any clunky sounds at all. and it just fired almost perfect sounding. there wasn't any odd timed pop sounds. it was like a machine gun firing with perfect spaces in between each explosion.
kind of like in this video. its hard to hear it.
http://www.youtube.com/watch?v=FN_H9ljgUKs
does it have to do with cams and springs. or is it an ignition thing.
Re: Super smooth tight fireing engine
yea l would like the same with my motor. l would have to say just the perfect combination build. everything was just built to a blueprint perfect to spec. correct crank,rods,pistons,bearings,cams,valvetrain. but lm sure its probally all Bisimoto parts and probally all stage 3. basically lots of money for parts/labor. also u have to consider thats a race car, not sure what u have but if its a dd/race car find a beater car and go for a good tear down and build up
MM Gruppe B
Albeit what you are hearing with the Bismoto, hard to tell with the damn music, is the faster idle speed which makes the engine sound smoother than stock I4s. There is also the factor of how the intake and exhaust systems are modified.
A big change in sound with V8s is when headers are added, outside of the slight tinney sound the more equal flow from a header, vs a log type manifold, will help balance out the exhaust pulses. Rather than a muffled burble you will hear a cackle. A properly constructed exhaust with a correctly placed crossover will also help balance out the exhaust pulses.
heres another video. it sounds a little gallop-y but maybe someone can spot a clue as to why this car is so ****ing fast and scary sounding. so far ive noticed that this car is STRIPPED !!
http://www.youtube.com/watch?v=TF4TG...eature=related
crx12
Welding / Fabrication
35
01-26-2007 09:52 PM
Driven
244
06-10-2003 05:54 PM
