Should I go for it or pass
Old 06-25-2006, 08:03 PM
f22 lx's Avatar
Default Should I go for it or pass
Hey, I've been wanting to do some work on my Accord since I got it a year ago and its still boring and stock. I was browsing CraigsList and found a 94 Vtec engine (assuming F22B1) with manual transmission and was wondering if it would be a good idea to do an engine and tranny swap on my accord (F22B2 - Auto). The engine and tranny have abuot 142k miles on them and my car has about 144k miles on the engine and about 70-80k on the rebuilt transmission. The guy is asking 250. Should I go for it or do something else.
Here's the description:
i have a 1994 accord sohc vtec motor and 5 spd trans 142k on them. you have to pick up. the motor is near Lake City Seattle. i have the axels wit ABS rings. ecu. no harness.. i want 250 o.b.o willing to work on the price for a quick sale. call me
What else will I need besides the parts for the 5 speed swap i know all those, most parts i can use from my accord already can't i?
Old 06-25-2006, 08:17 PM
hondaccord's Avatar
Default Re: Should I go for it or pass (f22 lx)
it sounds like a good deal, but if your going to do a swap you might want to save the extra and get a h23, or even a k series. the 94-97 Accord chasie can fit just about any honda block you want in it.
Old 06-25-2006, 08:37 PM
f22 lx's Avatar
Default Re: Should I go for it or pass (hondaccord)
i planned on buying an h22 from hmotors but it was just too expensive for me....how much would a h23 or k series run me?
Old 06-25-2006, 10:30 PM
f22 lx's Avatar
also how much more work is it with installing the vtec since i didnt have it before will i need extra materials for that?
Old 06-25-2006, 10:54 PM
momstaxi's Avatar
you will need two approx. 3 ft. wires and a vtec ecu to successfully wire in vtec to your car...
Old 06-26-2006, 12:37 AM
0x5359-0055
213374U's Avatar
Default Re: Should I go for it or pass (momstaxi)
Save your money for an H swap. The few extra horses you'll get from a B1 is not worth the time and effort.
Old 06-26-2006, 02:20 AM
CD5 Jeebies!'s Avatar
Location: Free bullets if you find me sucka, Washington
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi &raquo;</TD></TR><TR><TD CLASS="quote">you will need two approx. 3 ft. wires and a vtec ecu to successfully wire in vtec to your car...</TD></TR></TABLE>
3 wires........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 213374U &raquo;</TD></TR><TR><TD CLASS="quote">Save your money for an H swap. The few extra horses you'll get from a B1 is not worth the time and effort.</TD></TR></TABLE>
hahaha where have you been dood??? the F22b1 is a great motor! ...and a manual swap is a really good idea.........don't do the H22 swap..save your money...(wish I had)
and sheyit for 250!!!!! you can't go wrong!! make sure you get all the extras that come with the motor like the main engin harness, ECU, Clutch cylinder, blah blah blah...so you don't have to buy it later! good luck I say
GO FOR IT!
Old 06-26-2006, 03:21 AM
YeuEmMaiMai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaccord &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like a good deal, but if your going to do a swap you might want to save the extra and get a h23, or even a k series. the 94-97 Accord chasie can fit just about any honda block you want in it.</TD></TR></TABLE>
No, it cannot. You cannot fit a V6 into a 4cyl car 5th gen accord. While the F, H, and K series will work just fine, the J series will not fit becuase the engine bay is too small.
You have to buy a V6 car if you want to swap in a newer V6 into one.
The front end on a I4 is exactly 3" shorter than what you need to fit a V6 in there.
Starting in 1998, the engine bays are the same for the V6 and I4 although it is still kinda pricey to swap a V6 into a I4 car.
Old 06-26-2006, 07:05 PM
momstaxi's Avatar
Default Re: Should I go for it or pass (I got the CD5 Jeebies!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">3 wires........ </TD></TR></TABLE>
those two 3 ft. wire i suggested will more than cover from the vtec spool and pressure to the ecu, then just cut off about 4 inches from one to run a ground from the pressure switch to the solenoid itself.
Old 06-26-2006, 07:45 PM
i_kick_turtles's Avatar
If you are eventually going to go turbo, I would swap it. If you plan on staying naturally aspirated, I would save up for the h22. It's not worth the effort to have a na f22b in my opinion.
Old 06-27-2006, 02:05 AM
92ehatch's Avatar
Default Re: Should I go for it or pass (I R Tylor)
if the price of a h22 is a problem then possibly look into a jdm f22b
its basically the equivilent (minus .1 litre) of a usdm h23 but can be found for as little as 500 plus shipping.
Old 06-27-2006, 02:55 PM
f22 lx's Avatar
Default Re: Should I go for it or pass (93cb7sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93cb7sedan &raquo;</TD></TR><TR><TD CLASS="quote">if the price of a h22 is a problem then possibly look into a jdm f22b
its basically the equivilent (minus .1 litre) of a usdm h23 but can be found for as little as 500 plus shipping.</TD></TR></TABLE>
where are those at? i have yet to see one, could you lead me somewhere where i could find one, thanks!
Old 06-27-2006, 04:50 PM
hmotorsonline.com
ebay...
Old 06-27-2006, 08:16 PM
f22 lx's Avatar
yup i already checked those 2 places..... no luck
Old 06-27-2006, 09:26 PM
fishwgoose's Avatar
do it
Old 06-29-2006, 04:07 PM
It might not be a bad idea to buy the motor and tranny you are looking at and swapping a h23 head onto the block. It will be less expensive and easier to find than a f22b, but is essentially the same thing.
Old 07-01-2006, 08:47 PM
f22 lx's Avatar
hey all, the guy e-mailed me back and said he's willing to give me the engine and tranny with axels and ecu for 150 pickup, i think its pretty good deal, but i still need all the parts for a manual swap....would you go for it for only 150?!
Old 07-01-2006, 11:31 PM
Default Re: (f22 lx)
That is a really good deal for only 150.
Old 07-02-2006, 12:00 AM
BRNCD7's Avatar
It's ultimately your decision. The price seems good but the miles worry me. If you decide to go ahead a buy it check the engine and the tranny carefuly. Go over it with a microscope if you have to. You dont want to spend your hard earned money on a motor that has bent valves or scorned piston walls. You have to also ask yourself what do you want. an NA motor? turbo? Good luck.
DAfanatic
01-08-2007 08:23 AM
bigt61
04-15-2005 05:36 PM
Easyslider01
05-15-2004 07:19 AM
ACCORDPOWER97
10-10-2003 11:27 AM
Quick Reply: Should I go for it or pass
