H & F Series Engine Info
Blocks
BLOCK TYPE H22A = closed deck H22A1 = closed deck H22A4 = open deck H23A = open deck H23A1 = closed deck F20A = open deck F20B = open deck F22A = open deck F22B = open deck F22B1 = open deck F22B2 = open deck F23A = open deck DECK HEIGHT H22A = 219.5mm/8.643 H22A1 = 219.5mm/8.643 H22A4 = 219.5mm/8.643 H23A = 219.5mm/8.643 H23A1 = 219.5mm/8.643 F20A = 219.5mm/8.643 F20B = 219.5mm/8.643 F22A = 219.5mm/8.643 F22B = 219.5mm/8.643 F22B1 = 219.5mm/8.643 F22B2 = 219.5mm/8.643 F23A = 219.5mm/8.643 BORE H22A block = 87mm/3.425 H22A1 block = 87mm/3.425 H22A4 Block = 87mm/3.425 H23A block = 87mm/3.425 H23A1 block = 87mm/3.425 F20A block = 85mm/3.346 F20B block = 85mm/3.346 F22A block = 85mm/3.346 F22B block = 85mm/3.346 F22B1 block = 85mm/3.346 F22B2 block = 85mm/3.346 F23A block = 86mm/3.385 Rods LENGTH H22A = 143.0mm/5.633 H22A1 = 143.0mm/5.633 H22A4 = 143.0mm/5.633 H23A = 141.5mm/5.572 H23A1 = 141.5mm/5.572 F20A = 145.0mm/5.709 F20B = 145.0mm/5.709 F22A = 141.5mm/5.572 F22B = 141.5mm/5.572 F22B1 = 141.5mm/5.572 F22B2 = 141.5mm/5.572 F23A = 141.0mm/5.551 WIDTH H22A = 23.75mm/.935 H22A1 = 23.75mm/.935 H22A4 = 23.75mm/.935 H23A = 23.75mm/.935 H23A1 = 23.75mm/.935 F20A = 23.75mm/.935 F20B = 23.75mm/.935 F22A = 23.75mm/.935 F22B = 23.75mm/.935 F22B1 = 23.75mm/.935 F22B2 = 23.75mm/.935 F23A = 19.81mm/.780 MAIN BORE H22A = 51.00mm/2.008 H22A1 = 51.00mm/2.008 H22A4 = 51.00mm/2.008 H23A = 51.00mm/2.008 H23A1 = 51.00mm/2.008 F20A = ??? F20B = 48.00mm/1.890 F22A = 51.00mm/2.008 F22B = 51.00mm/2.008 F22B1 = 51.00mm/2.008 F22B2 = 51.00mm/2.008 F23A = 48.00mm/1.890 PIN BORE H22A = 21.97-21.98mm/.8649-.8654 H22A1 = 21.97-21.98mm/.8649-.8654 H22A4 = 21.97-21.98mm/.8649-.8654 H23A = 21.97-21.98mm/.8649-.8654 H23A1 = 21.97-21.98mm/.8649-.8654 F20A = 21.97-21.98mm/.8649-.8654 F20B = 21.97-21.98mm/.8649-.8654 F22A = 21.97-21.98mm/.8649-.8654 F22B = 21.97-21.98mm/.8649-.8654 F22B1 = 21.97-21.98mm/.8649-.8654 F22B2 = 21.97-21.98mm/.8649-.8654 F23A = 21.97-21.98mm/.8649-.8654 Pistons BORE H22A = 87mm/3.425 H22A1 = 87mm/3.425 H22A4 = 87mm/3.425 H23A = 87mm/3.425 H23A1 = 87mm/3.425 F20A = 85mm/3.346 F20B = 85mm/3.346 F22A = 85mm/3.346 F22B = 85mm/3.346 F22B1 = 85mm/3.346 F22B2 = 85mm/3.346 F23A = 86mm/3.385 COMPRESSION HEIGHT H22A = 31.0mm/1.221 H22A1 = 31.0mm/1.221 H22A4 = 31.0mm/1.221 H23A = 30.5mm/1.203 H23A1 = 30.5mm/1.203 F20A = ??? F20B = 31.0mm/1.221 F22A = 30.5mm/1.203 F22B = 30.5mm/1.203 F22B1 = 30.5mm/1.203 F22B2 = 30.5mm/1.203 F23A = 30.0mm/1.181 PISTON VOLUME H22A = -1.9 cc H22A Type S = +4.2 cc H22A1 = -1.8 cc H22A4 = -1.8 cc H23A = +4.3 cc H23A1 = -9.9 cc F20A = -4.7 cc F20B = +8.0 cc F22A = -14.5 cc F22B = -11.2 cc F22B1 = -14.5 cc F22B2 = -14.5 cc F23A = -18.0 cc WRIST PIN DIAMETER H22A = 22.0mm/.866 H22A1 = 22.0mm/.866 H22A4 = 22.0mm/.866 H23A = 22.0mm/.866 H23A1 = 22.0mm/.866 F20A = 22.0mm/.866 F20B = 22.0mm/.866 F22A = 22.0mm/.866 F22B = 22.0mm/.866 F22B1 = 22.0mm/.866 F22B2 = 22.0mm/.866 F23A = 22.0mm/.866 Crankshafts STROKE H22A = 90.7mm/3.570 H22A1 = 90.7mm/3.570 H22A4 = 90.7mm/3.570 H23A = 95mm/3.740 H23A1 = 95mm/3.740 F20A = 88mm/3.464 F20B = 88mm/3.464 F22A = 95mm/3.740 F22B = 95mm/3.740 F22B1 = 95mm/3.740 F22B2 = 95mm/3.740 F23A = 97mm/3.818 MAIN JOURNAL DIAMETER H22A = 50mm H22A1 = 50mm H22A4 = 55mm H22A4 = 50mm (1997 Only) H23A = 55mm H23A1 = 50mm F20A = 50mm F20B = 55mm F22A = 50mm F22B = 50mm F22B1 = 50mm F22B2 = 50mm F23A = 55mm ROD JOURNAL DIAMETER H22A = 47.95mm/1.888 H22A1 = 47.95mm/1.888 H22A4 = 47.95mm/1.888 H23A = 47.95mm/1.888 H23A1 = 47.95mm/1.888 F20A = 47.95mm/1.888 F20B = 44.98mm/1.771 F22A = 47.95mm/1.888 F22B = 47.95mm/1.888 F22B1 = 47.95mm/1.888 F22B2 = 47.95mm/1.888 F23A = 44.98mm/1.771 Cylinder Heads HEAD VOLUME H22A = 53.8cc H22A1 = 53.8cc H22A4 = 53.8cc H23A = 53.8cc H23A1 = 50.0cc F20A = 50cc F20B = ??? F22A = 50.5cc F22B = 50.5 F22B1 = 50.6cc F22B2 = 50.6cc F23A = ??? INTAKE VALVE DIAMETER H22A = 35mm/1.38 H22A1 = 35mm/1.38 H22A4 = 35mm/1.38 H23A = 35mm/1.38 H23A1 = 34mm/1.34 F20A = 34mm/1.34 F20B = 34mm/1.34 F22A = 34mm/1.34 F22B = 34mm/1.34 F22B1 = 34mm/1.34 F22B2 = 34mm/1.34 F23A = 34mm/1.34 EXHAUST VALVE DIAMETER H22A = 30mm/1.18 H22A1 = 30mm/1.18 H22A4 = 30mm/1.18 H23A = 30mm/1.18 H23A1 = 29mm/1.14 F20A = 29mm/1.14 F20B = 29mm/1.14 F22A = 29mm/1.14 F22B = 29mm/1.14 F22B1 = 29mm/1.14 F22B2 = 29mm/1.14 F23A = 29mm/1.14 Head Gaskets BORE H22A = 88mm/3.46 H22A1 = 88mm/3.46 H22A4 = 88mm/3.46 H23A = 88mm/3.46 H23A1 = 88mm/3.46 F20A = 85.5mm/3.37 F20B = 85.5mm/3.37 F22A = 85.5mm/3.37 F22B = 85.5mm/3.37 F22B1 = 85.5mm/3.37 F22B2 = 85.5mm/3.37 F23A = 86.5mm/3.41 THICKNESS H22A = 0.66mm/.026 H22A1 = 0.66mm/.026 H22A4 = 0.66mm/.026 H23A = 0.66mm/.026 H23A1 = 0.66mm/.026 F20A = 0.66mm/.026 F20B = 0.66mm/.026 F22A = 0.66mm/.026 F22B = 0.66mm/.026 F22B1 = 0.66mm/.026 F22B2 = 0.66mm/.026 F23A = 0.66mm/.026 Note: Gasket thickness measured after crush Bearings MAIN BEARING THICKNESS Blue: 2.013 - 2.010mm / 0.0793 - 0.0791 Black: 2.010 - 2.007mm / 0.0791 - 0.0790 Brown: 2.007 - 2.004mm / 0.0790 - 0.0789 Green: 2.004 - 2.001mm / 0.0789 - 0.0788 Yellow: 2.001 - 1.998mm / 0.0788 - 0.0787 Pink: 1.998 - 1.995mm / 0.0787 - 0.0785 Red: 1.995 - 1.992mm / 0.0785 - 0.0783 ROD BEARING THICKNESS Blue: 1.510 - 1.507mm / 0.0594 - 0.0593 Black: 1.507 - 1.504mm / 0.0593 - 0.0592 Brown: 1.504 - 1.501mm / 0.0592 - 0.0591 Green: 1.501 - 1.498mm / 0.0591 - 0.0590 Yellow: 1.498 - 1.495mm / 0.0590 - 0.0589 Pink: 1.495 - 1.492mm / 0.0589 - 0.0587 Red: 1.492 - 1.489mm / 0.0587 - 0.0586 MAIN BEARING WIDTH H22A = 19.9mm/.784 H22A1 = 19.9mm/.784 H22A4 = 19.9mm/.784 H23A = 19.9mm/.784 H23A1 = 19.9mm/.784 F20B = 19.9mm/.784 F22A = 19.9mm/.784 F22B = 19.9mm/.784 F22B1= 19.9mm/.784 F22B2= 19.9mm/.784 F23A = 19.9mm/.784 ROD BEARING WIDTH H22A = 19.35mm/.762 H22A1 = 19.35mm/.762 H22A = 19.35mm/.762 H23A = 19.35mm/.762 H23A1 = 19.35mm/.762 F20A = 19.35mm/.762 F20B = 19.35mm/.762 F22A = 19.35mm/.762 F22B = 19.35mm/.762 F22B1 = 19.35mm/.762 F22B2 = 19.35mm/.762 F23A = 15.47mm/.609 ** Full credit goes to Innovation, PirateMcFred, prelittledude, Jdogg, ZigenBallz and HondaFan81 for this information. ** https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif |
Re: H & F Series Engine Info (hondaccord)
Would make a nice sticky...
Okay this may be a dumb question but I need to kill any doubt for a friend.
Does an H22 head fit an F22 BLOCK. I say no. She doesnt believe me. Help me fellas! |
Re: (bluetintruben)
search. the short answer is yes it does, this has been covered a million times.
Damn so it does? I've never seen it done before. Is it a straight bolt up or what?
Re: (bluetintruben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluetintruben »</TD></TR><TR><TD CLASS="quote">Damn so it does? I've never seen it done before. Is it a straight bolt up or what?</TD></TR></TABLE>
like stated above, search. Or better yet, go into the FAQ and under the Swaps section you'll see some links to it. Lots of info on that swap out there. |
Re: H & F Series Engine Info (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S »</TD></TR><TR><TD CLASS="quote">Would make a nice sticky...</TD></TR></TABLE>
not a sticky, too many as it is... but I will add this to the FAQ https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: H & F Series Engine Info (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">
not a sticky, too many as it is... but I will add this to the FAQ https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/embeer.gif |
Re: H & F Series Engine Info (Fern413)
I thought it would be good in the accord faq too, but George Knighton said to just post it up. so I guess I just did what I was told to do. and as far as the h/f swap as far as I've seen the h23 head is easier to swap on then the h22.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaccord »</TD></TR><TR><TD CLASS="quote">I thought it would be good in the accord faq too, but George Knighton said to just post it up.</TD></TR></TABLE>
right, we don't post the info straight into the FAQ. the user makes a thread for the info, then we link that thread into the FAQ https://honda-tech.com/forums/images/smilies/emthup.gif |
cool wasn't sure how that worked but good to know. https://honda-tech.com/forums/images/smilies/emthup.gif
There is a mistake in that list.
The piston volume for the F23's are not all the same. The F23A1/A4 are -13.6. The F23A5 has a piston volume of -18. Just a heads up. |
Re: H & F Series Engine Info (S-spec)
I wish i knew how to use all that info.... http://images.honda-tech.com/set1//smile/emcrook.gif
Re: H & F Series Engine Info (Andryzzle)
are any F-series motors FRM
Re: H & F Series Engine Info (BIG T)
just the f20c/f22c found in the s2k uses frm
Re: H & F Series Engine Info (street_accord94)
see i thought that F22B's were cast iron sleeves factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG T »</TD></TR><TR><TD CLASS="quote">see i thought that F22B's were cast iron sleeves factory</TD></TR></TABLE>
not cast, but iron yes |
Another heads-up, the f22b2 intake valve is actually 32mm.
Sources: 1) AEM Engine ID and Spec Chart 2) 94 Accord Coupe Shop Manual Section 6 pages 39-40 |
Hello,
i have a new used f20b dohc i need to overhaul the engine. im a newbie not much knowing some parts of the engine.. planning to buy the overhauling kit and i head that h22a can be use for f20b and how about the piston rings, crankshaft main bearing and the connecting rod? i don't see many parts of f20b so i might thinking that the h22a can be fit for f20b? hope i can hear some good responds in the group. THanks. |
