Going back into the crank shaft 98 V6
Old 04-23-2019, 10:54 PM
XRACER63's Avatar
Default Help please 🙏Going back into the crank shaft 98 V6
The balancer is at where it tells you but not where I marked it originally. The crank is at 11:50 not 12:00
I had the balancer lined up on arrow but the crank wasn’t at 12 o’clock the valve pulleys where at 1. I have not worked on the car since. I want to take it apart again and realign the crank shaft to the correct mark any suggestions ? Photo is where it should be not where it is cure at 11:50 not 12:00 🕛
sheehan024
08-21-2005 07:38 PM
flat-blk-HB
01-13-2004 07:26 PM
Quick Reply: Going back into the crank shaft 98 V6
